front ice chest
Boating 101
Old 07-01-2009, 11:26 PM   #1
DawgDaze is currently offline
My Model: 1998 214 Jub
Send DawgDaze:
Default front ice chest
Went to the lake today and had a great time with family. I have a 99 214 jubilee and used the front ice chest for the first time. Where does the water go. I cleaned it out this morning with a hose and didnt see water coming out anywhere. When I got back this evenning i took the drain plug out and more water came out than usual. Was think it may just drain in the bottom of the boat seeing how it isnt much when you use ice.
Just Do It!
  • Old 07-02-2009, 12:29 AM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: front ice chest
    It's pretty common for boat-makers to drain built-in ice chests into the bilge. Our Pearson P30 (sailboat) has a hose coming out the bottom of the built-in ice chest that just lays in the bottom of the engine space. It's plugged on the end, otherwise the water would end-up in the bilge. I don't like any more water in the bilge than necessary, so I manually drain it into a bucket and toss it overboard.
    Jim
    Old 07-02-2009, 02:32 AM   #3
    Send DawgDaze:
    Thanks Jim. Glad I didn't let the hose run longer. Funny the bilge pump didnt kick on. Will check that this week.
    Just Do It!
    Old 07-02-2009, 02:37 AM   #4
    SEMIJim's Avatar
    Send SEMIJim:
    Probably not enough water to trip the switch.
    Jim
    Old 07-08-2009, 04:37 AM   #5
    SEMIJim's Avatar
    Send SEMIJim:
    Confirmed. I checked the bilge pump float switch after I got the bilge pump running. There has to be quite a bit of water in the bilge to trip that float switch.
    Jim
    Old 07-08-2009, 01:50 PM   #6
    Send DawgDaze:
    Thanks again Jim for looking into that. Maybe I can help you with something one day.
    Buddy
    Just Do It!
    Old 07-08-2009, 04:39 PM   #7
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    On my 202 the front cooler drains into the bilge. The cooler in the passenger dash drains out the side of the hull.
    And my bilge also has to be pretty full to trip the float switch.
    My Mariah
    Old 09-29-2009, 09:56 PM   #8
    daveraymyers's Avatar
    daveraymyers is currently offline
    My Model: 190 Talari
    My Engine: 4.6LX Alpha I Gen II
    Gallery Images: 15
    Send daveraymyers:
    Does anyone know where the front ice chest water drains on my 1995 Mariah 190 Talari? I filled the ice chest with drinks and ice on the morning on a pretty hot day, and about 2 hours later went to a lake that has the "no standing water" rule, and there was too much water in my ski locker so they didn't let me in. All was good because we ended up going to another lake that did not have the inspections and had an awesome day!!!
    Dave
    Old 09-30-2009, 09:43 AM   #9
    Hi Dave, it should drain down to the keel and flow back to the bilge where you can use the bilge pump or if it's on land, the drain plug.
    Old 10-01-2009, 12:30 AM   #10
    Gallery Images: 15
    Send daveraymyers:
    Hey WetWilly!
    Thanks for the info! I'll keep my eye on the ski locker and make sure it drains properly.
    -Dave
    MCC Canvas tops/front panels thawk Original Mariah Talk 0 06-09-2009 11:56 PM
    Front Speakers not working... Z272 Original Mariah Talk 4 05-05-2008 05:57 PM
    Front Towbars... whats your experience bakdraft Trailering and Tow Vehicles 13 04-03-2008 06:52 PM
    Scans from the front of the maual... ChicagoWeb Original Mariah Talk 0 07-31-2007 04:51 PM
    There are 366 users
