front ice chest
Boating 101
Old 07-08-2010, 05:02 PM   #11
MissouriBoater79's Avatar
MissouriBoater79 is currently offline
My Model: Z222 Shabah
My Engine: 5.7L Alpha One Drive
Send MissouriBoater79:
Default Re: front ice chest
Anyone have issues with the front ice chest (bowrider) leaking water? Mine appears on the carpet right between the bow's nonskid flooring and the ski locker. Ski locker is dry. My husband did a thourough wax job last weekend and is now convinced that it is not a cooler at all. 2001 Shabah 222.
  • Old 07-08-2010, 06:34 PM   #12
    Mine drains out of the hull on the front port side. Check to see if the drain tube is cracked or separated.
    Old 07-08-2010, 06:45 PM   #13
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Is it kinda funnel shaped in the bottom, with a hole in the middle? If so: Odds are it's a cooler.
    Jim
    Old 07-08-2010, 07:04 PM   #14
    it is! it is an inverted pyramid with a drain hole at the bottom. Ice melts/drains mighty fast, so its hard to keep drinks cold in there, but it is nice to have.
    so...if the drain opens up into the hull? Rough water might cause it to slosh around and leak out?
    Old 07-08-2010, 08:31 PM   #15
    SEMIJim's Avatar
    Send SEMIJim:
    No clue, on your boat. On our '94 182 Barchetta it drains into the ski locker, thus eventually into the bilge.
    Mariah did so many other things so well, I wish they'd run a hose back to the bilge, so icewater wasn't getting the ski locker wet. Once that thing gets wet, it never gets dry again all season, and it can get pretty nasty
    Jim
    Old 07-08-2010, 09:22 PM   #16
    huh? Mine has a drain line that runs to a fitting in the hull which allows it to drain overboard.
    MCC Canvas tops/front panels thawk Original Mariah Talk 0 06-09-2009 11:56 PM
    Front Speakers not working... Z272 Original Mariah Talk 4 05-05-2008 05:57 PM
    Front Towbars... whats your experience bakdraft Trailering and Tow Vehicles 13 04-03-2008 06:52 PM
    Scans from the front of the maual... ChicagoWeb Original Mariah Talk 0 07-31-2007 04:51 PM
    There are 251 users
