Mystery Plug
Boating 101
Old 03-21-2009, 12:38 AM   #1
Corndog is currently offline
My Model: 1998 180 Shabah 4.3 L Merc
Send Corndog:
Question Mystery Plug
I found a "mystery" plug in my recently purchased 98 Shabah 180. This is my first boat and quite frankly, I have a lot to learn. Anyway, I found what looks like a plug of some kind in the captain cup holder. It is threaded and looks like it is made of brass or something similar. It is about 1/2 inch in diameter and 3/4 inch long. I'm told the boat was winterized. Is the plug perhaps removed for winterization? Is it a drain for the boat or maybe a soft plug for the motor? I have no idea where it might belong. Any help would be much appreciated.
  • Old 03-21-2009, 01:09 AM   #2
    Send Corndog:
    Default Re: Mystery Plug
    One more thing. There is no lanyard for the kill switch that is on the bottom of the throttle. Will the boat start and run without it? Where could I get a replacement? Thanks again for any input.
    Corndog
    Old 03-21-2009, 01:31 AM   #3
    Irace82's Avatar
    Irace82 is currently offline
    My Model: 1993 Shabah 198 4.3LX Alpha I
    Send Irace82:
    Does your "mystery" plug look like the one below? If so it is...
    Product Description:
    Bronze 1/2" NPT replacement plug for garboard drain. Used as transom drain on many current model powerboats. You should always carry a spare. "Just In Case".
    (This pic and info is provided my wholesalemarine.com)
    Old 03-21-2009, 01:47 AM   #4
    Hi Corndog and welcome to the club!
    It sounds like you have the main drain plug for the hull and it probably has a square protruding from one end, like the one in the picture Irace82 posted. This is for a 1/2" wrench for loosening and tightening.. Look at the back of your boat underneath the outdrive and you will see a brass drain port located at the very bottom of the transom. This is where that brass plug of yours should go.
    Since you mentioned that your Mariah was winterized and this is your first boat, I suggest having a mechanic or someone very knowledgeable with your motor and outdrive to explain what measures were done for the winterizing and what you need to do to put it back into service. This normally involves reinstalling the motor and exhaust manifold water drain plugs, possible oil change, general tuneup and possibly a water pump impeller change. Don't forget the trailer if you have one.
    I know it sounds like a lot but it really isn't once you're familiar with the routine!
    The motor will still run without the Lanyard as long as the kill switch is in the correct position, which I believe is in the down position for RUN. Replacement Lanyards are available and any good boating store should carry or have access to them. I had to get one myself, got it from West Marine, they're on the web
    Old 03-21-2009, 02:47 AM   #5
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    I found the use of this plug is optional and only needs to be used if you want the boat to float for a extended of period of time!
    Several years ago, in my 210 Talari, after motoring out to the swimming area; one of the kids still in the boat ask where all the water was coming from. I got into the boat to find water coming out from under the motor box. I immediately remembered taking out the plug at home and leaving it in the garage. I jumped back into the water and covered the hole with my hand. I had everyone to get back into the boat. I then got into the boat started the bilge pump, started the engine, and took off on plane so water would drain out the plug hole. After water stopped coming out from the bilge, I stopped the boat, jumped out, covered the hole and had my wife give me the extra plug. I "ALWAYS" carry one and know right were it is! The rest of the day we spent in the sun! So "always always" carry a extra plug.
    Almost every boater will tell you they have forgotten to replace the drain-plug once or twice.(Or lie about it)
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 03-22-2009, 03:44 PM   #6
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Well, (touch wood) I haven't done it with my Mariah... yet...
    I do remember back in the 80's, lauching my dad's Baja with the Dodge Magnum. He forgot to put the plug in... I was manning the ropes on the dock and he was getting ready to fire it up when he noticed the water coming up in the bilge. Fortunately we got it back on the bunks fairly quickly, and the smoke show the car provided as it tried to pull that load back up the steep and slippery ramp was quite spectacular...
    I always carry a spare plug in the boat, and a spare wrench in the console of my Jeep, so I always have it handy at launch time.
    My Mariah
    Old 03-22-2009, 06:27 PM   #7
    Send Corndog:
    Thank You All. My "mystery" plug is the same as one in the photo so... mystery solved. Great advice about carrying a spare plug, having a mechanic walk me through the spring startup, where to get a replacement lanyard, etc. I will take all your advice and am very appreciative. Happy boating.
    Old 03-22-2009, 07:16 PM   #8
    Hi Corndog,
    It was our pleasure!
    Here is something else that will come in handy until you get into the "boating" routine... it's a checklist created by our member Dudders.
    It's divided into two responsibilities, yours and your first mate/wife/girl friend/etc and the drain plug is referred to as "BUNG" on the list...
    Old 03-22-2009, 10:35 PM   #9
    z275st's Avatar
    Gallery Images: 33
    Send z275st:
    Hi Corndog,
    I guess that makes that opening a "BUNG HOLE"
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 03-28-2009, 05:48 PM   #10
    LHC Kirby is currently offline
    My Model: 2001 245
    My Engine: 5.? Volvo Penta
    Send LHC Kirby:
    Talking Re: Mystery Plug
    I found a "mystery" plug in my recently purchased 98 Shabah 180. This is my first boat and quite frankly, I have a lot to learn. Any help would be much appreciated.
    Based on the info above - all boaters, and new ones like yourself - Must take a boaters safety course. Bring the wife and any children that may be operating the boat in the next year. It will be time well spent, and get you a discount on your boat insurance too.
    If you did not know what the plug is, that is a real good sign, that a safety class is going to teach you a lot.
    Enjoy the Mariah and your next bigger boat (common thing, if you love boating, is to go bigger next time)
    Spark plug MMarko Original Mariah Talk 1 03-16-2009 02:13 PM
    mystery guage on dash panel? 2005expedition Original Mariah Talk 2 03-19-2008 03:10 PM
    There are 307 users
