neep advice
Watersports
Old 07-02-2010, 12:33 PM   #1
bdydrpranger95 is currently offline
Send bdydrpranger95:
Default neep advice
whats the best way to pull 2 tubes at once get one of those harness things and use the tow ring or would it be ok to clip them on to the transom tie down hooks ( i think its called) on each side of the boat thats what my buddy does on his mastercraft but his sticks out the water even just sitting there by the way i have a 2000 mariah shabah z182 with the 4.3
thanks in advance
  • Old 07-02-2010, 01:01 PM   #2
    Default Re: neep advice
    Hi bdydrpranger95, For a single towable, I use the ski hook. For two towables, I just use the tie-downs and for three towables it's the tie-downs and the ski hook.
    If you're not comfortable using the ski hook, a harness clipped to the two transom tie-downs will work just fine. I recommend the type that has a small float attached to keep it away from the prop.( I use this same type when we have tube wars on the water. Both tubes are connected at the harness ring so they stay together when running in a straight line. Take a few turns , when straighten out and the tubes go flying back at each other...bump, bump, bump...
    Old 07-02-2010, 06:12 PM   #3
    ok thanks for the input i didnt know if it was safe to do it like that since when you come to a stop the ropes under water
    Old 07-03-2010, 07:26 AM   #4
    Typically, tow and ski ropes tend to float on top of the water and there is always a little tension on them if you're moving, but if you're still worried about it then see if you can locate a couple of small plastic swimming pool floats that go over the lane divider ropes. Attach these to the tow ropes a foot or two from the transom and it will be harder for the lines to get caught in the prop.
    As for myself, I try to never just stop if I can help unless it's an emergency, because it can throw passengers around quite abruptly and potentially cause the lines to tangle with the outdrive. Instead, I throttle down quickly then I turn around to pick up any fallen buddies or to retrieve the pooped ones
    Another thing, here in California, the law says there has to be a dedicated spotter at all times when doing any water sports like skiing , wake-boarding or tubing, so there is someone always watching the ropes, gear and people in the water allowing the driver to just focus on driving.
    Need some advice on a prop for B3 schmitty Prop Talk 5 06-07-2010 06:15 PM
    Need Advice Mariah Z202 Boating 101 3 07-16-2009 01:12 AM
    Advice brucedennis1 Original Mariah Talk 2 04-02-2009 10:33 PM
    Thanks for all your advice Colin T Chit Chat/Off-Topic 4 01-04-2008 06:48 AM
    Need Advice Please Sheli Sea Fox - Mariah Talk 6 07-23-2007 01:43 AM
    There are 237 users
