Outdrive tried to jump ship
Volvo Penta
Old 07-21-2013, 12:08 AM   #11
Default Re: Outdrive tried to jump ship
Sounds like the shift arm might not be in the right place.
Not real sure on the VP drives , but gotta be in forward gear on the Merc drives.
I'll do some searching , and in the meantime , maybe one of the VP boys will chime in with a answer.
Update: Looks like you need the shifter in neutral.
  • Old 07-21-2013, 12:13 AM   #12
    Check out this post from marine engine.com.
    Old 07-21-2013, 12:36 AM   #13
    Rynovw's Avatar
    Rynovw is currently offline
    My Engine: 1 man power & a PFD
    Send Rynovw:
    Thank you for the reply I was thinking the same thing last night so we pulled the drive shaft off the drive uint so we could slide it in and out easy. its stoping just before the o-rings
    looking for a new ride. other then the 1 man powered PFD i currently have
    Old 07-21-2013, 01:13 AM   #14
    You did realign the gimble to the motor right? ( Don't mean to seem anal)
    It almost sounds like a alignment issue. If it isn't just right it won't go in.
    Is it possibly hanging on the inside of the driveshaft boot?
    I'll continue to look for a solution.
    Old 07-21-2013, 01:28 AM   #15
    Rynovw's Avatar
    Send Rynovw:
    yes aligning gimbal to motor ill go by the shop and get a pic tonight. im on shift tomorrow so ill have a ton of time to research too.
    Old 07-21-2013, 01:28 AM   #16
    I found the process in the "Volvo Outdrives Workshop Manual" here on MOC.
    Go to page 132 and see if that looks familiar.
    VP drives are a whole new ball of wax for me , sorry.
    Old 07-21-2013, 02:38 AM   #17
    Rynovw's Avatar
    Send Rynovw:
    I've been reading the manual thanks for having those on here for us.
    Here's the parts I'm fighting.
    The drive shaft only slides in as far as the shine spot on the shaft.
    Old 07-21-2013, 02:51 AM   #18
    Did you try fitting the gimble bearing to the shaft before you installed the bearing?
    Is there possibly an old O-ring in the groove inside the housing?
    Does your alignment tool seat all the way in?
    Maybe mike the driveshaft bearing area with calipers to make sure it's round?
    Burrs maybe?
    Bent shaft?
    Stuff you probably already thought of ..........but maybe!
    How far are you from Denver? Road trip to see this cluster!!
    Gotta be something simple!!
    Old 07-21-2013, 03:00 AM   #19
    Rynovw's Avatar
    Send Rynovw:
    Crazy how most of us on here think the same. I did do all that and it fits great till you put them all together. Ok here's where you guys get to poke me. I didn't buy the tool I'm using the drive shaft itself to align it. The tool was nothing more then a drive shaft with no yoke. So I didn't see the $140 need for it. But I'm going to pay somebody Monday that I know to fix it. Lol
    Old 07-21-2013, 03:05 AM   #20
    Should have worked. I'm wondering if the shaft isn't bent.
    Did it eat a U-joint or two?
    Weird ass stuff for sure!!
    Sorry I couldn't help more.
    Make damn sure you let us know what you find.
    Day 4 of owner ship, need a prop now :( nglauer Prop Talk 2 07-05-2010 01:21 PM
    Mariah among other manufacturers ship TomasSE Sea Fox - Mariah Talk 2 04-21-2010 09:53 PM
    Anyone remember the wakeboard ballasts that doubled as rear jump seats ? jsp270 Watersports 3 02-18-2010 02:10 PM
    Somebody needs to jump on this one SamnBonnie Mariah Boats For Sale & Wanted 4 09-23-2008 02:56 PM
    There are 289 users
