Nauticus Smart Tabs and Trailering and the PR500
Trailering and Tow Vehicles
Old 07-08-2014, 03:43 PM   #1
FreshWaterFun is currently offline
My Year: 2011
My Model: R19
My Engine: 4.3 Merc Alpha One
Send FreshWaterFun:
Question Nauticus Smart Tabs and Trailering and the PR500
OK, I'm sold...I want the Smart Tabs to correct my porpoising and help with planing! I've seen several pictures in the forums with them installed and the boats are on trailers so it appears that as long as the supports on the trailer don't stick out past the transom you are OK even without the PR500 bracket?
I'm considering putting the PR500 bracket on anyway as doing this later would result in different holes being drilled than the standard bracket and this allows me to disengage the tabs at anytime. Anyone have experience with these either good or bad?
  • Old 07-08-2014, 04:07 PM   #2
    Bosgarage57 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    Default Re: Nauticus Smart Tabs and Trailering and the PR500
    no experience but I will be doing the same thing this winter when I install a tower. Gonna get the SX Tabs and PR500 bracket.
    Old 07-08-2014, 04:24 PM   #3
    My Year: 2011
    My Model: R19
    Send FreshWaterFun:
    Question Re: Nauticus Smart Tabs and Trailering and the PR500
    I should have been more clear. The "these" I was referring too are the PR500 brackets. Does anyone have experience with these either good or bad?
    Old 07-08-2014, 09:58 PM   #4
    Yep ,
    Had them on the Smart Tabs on my old VIP boat.
    To be honest , the only time I saw any real benefit from them was when I was drifting to control excessive wandering or when I was deep trolling using the tabs to slow the boat a bit.
    I never once used the PR500 as a disconnect feature , nor do I see a benefit of doing that.
    nauticus , pr500 , smart tabs
    Nauticus smart tab install question.. yblockmike Boating 101 2 07-19-2010 01:03 AM
    Smart Tabs cometb Original Mariah Talk 4 07-02-2010 09:35 PM
    Smart Tabs karmann Original Mariah Talk 13 07-22-2009 06:21 PM
    There are 262 users
