Excessive Trailer tire wear
Trailering and Tow Vehicles
Old 06-29-2012, 11:32 PM   #1
brit441 is currently offline
My Model: 1998 Z276 MCC
Send brit441:
Default Excessive Trailer tire wear
We tow our Z276MCC on a Chariot Triple axle trailer that has a serious appetite for front tires.
We are getting only about 1,200 to 1,500 miles per set. We carefully monitor the pressure and rotate about once a year. I am currently running ST 215 75R14 radial load range C trailer tires.
What kind of average wear should I expect from a triple axle trailer tire?
Also, Due to the bumper height of my tow vehicle, I use an 8 inch dropped hitch to keep the trailer somewhat level. Could I be causing the front tire wear by using this dropped hitch? Maybe raising the hitch height slightly will reduce the load on the front tires.
Any comments or suggestions will be appreciated.
Best Regards, Rick
brit441
  • Old 06-30-2012, 12:23 AM   #2
    Default Re: Excessive Trailer tire wear
    Are they wearing on the inside or outside of the tire?
    Larry
    Old 06-30-2012, 12:37 AM   #3
    Send brit441:
    On the front two tiress, wear is on the inside...by a substantial margin. On the rest of the tires wear is even but excessive in my opinion.
    Old 06-30-2012, 12:41 AM   #4
    Bent axle tube sounds like. Pull a string line from hub to hub and measure from string to axle tube. I bet in the middle you got a larger gap than at the hubs.
    Larry
    Old 06-30-2012, 12:42 AM   #5
    Also sounds like you might want to go to a D range tire.
    Larry
    Old 06-30-2012, 01:17 AM   #6
    Send brit441:
    Larry:
    Great idea!
    I'll go out and pull a string from hub to hub and let you know.
    Seems like I tried to go to a D range tire a few years ago, I think 14" D range trailer tires were hard to find. I may have to go to 15 inch rims and tires , after I sort out the axle issue.
    Thanks for the help!
    Rick
    Old 06-30-2012, 02:28 AM   #7
    I can't believe that they put 14" wheels on a triple anyway. Your boat weighs in at around 7500 lbs depending on options and loaded or not. Add another 1500-2000 lbs at least for the trailer and that's a lot for a 14" C tire to handle.
    Is that trailer the one that came with your 276?
    Larry
    Old 06-30-2012, 03:58 AM   #8
    Send brit441:
    Larry:
    Checked axle with a string line and found no significant bend.
    Also checked front axle from a fixed point @ front of trailer. Found about 1/2" difference to each backer plate. Not sure this would cause the tire wear I have been experiencing.
    The trailer was manufactured by Mariah for this boat. I agree with your assesment regarding tire size and load capacity. Current tires are good for11,100 lbs. The boat came with 4k genset and as you said, with the trailer,120gal fuel, water and god knows how much beer... I am pushing the limits of the tires.
    So instead of a new stereo this year it looks like new tires and rims.
    Larry, thanks for taking the time to help me through this, I will keep you posted as I progress.
    Best Regards,
    Rick
    Old 06-30-2012, 04:34 AM   #9
    Can you measure from a known point in the front to the axle tube on each side? Maybe the axle has shifted front to back. This usually happens from loose u bolts or a broken center pin in the leaf pack.
    Larry
    Old 06-30-2012, 05:43 AM   #10
    Send brit441:
    Larry:
    Measured from a fixed point @ the hitch back to both spindles. Found front axle racked about 1/2 inch back on the right side. I am not sure this would cause tire wear, but I am going to confirm axle location tomorrow and loosen u-bolts and try to move it bit closer to square.
    Also noticed that carlisle tires are wearing much faster than Westlake tires.
    Rick
    Trailer Spare Tire Location Douglas Alderman Trailering and Tow Vehicles 4 01-10-2012 01:41 PM
    need a new trailer racer3737 Original Mariah Talk 2 08-23-2011 07:40 PM
    need a new trailer darkcalling Trailering and Tow Vehicles 32 07-27-2011 12:32 AM
    Spare tire mount on a 1996 Chariot Trailer scubydo Trailering and Tow Vehicles 3 07-25-2011 06:20 PM
    My trailer fix Mark Original Mariah Talk 0 09-09-2008 11:39 AM
    There are 338 users
