Excessive Trailer tire wear
Trailering and Tow Vehicles
Old 06-30-2012, 03:43 PM   #11
Default Re: Excessive Trailer tire wear
That will definately cause a tracking problem. Make sure you check the center pin on that side too.
I run Goodyear Marathons on my trailers and really like them. However , they are a little spendy.
Try running the trailer for maybe 30 miles after you move the axle. If you'll mark the tire where it is wearing so bad with chalk(the inside) it should give you a idea if it helped or not.
Here are the 225/15's that I run on my tandem axle car trailer
http://www.tirerack.com/tires/tires....R8V2&tab=Specs
Larry
  • Old 07-20-2012, 10:02 PM   #12
    brit441 is currently offline
    My Model: 1998 Z276 MCC
    Send brit441:
    Finally had an opportunity to address the tire wear issue on my triple axle trailer.
    As stated in previous posts the right front tire was toed out approximately 1/2 to 5/8 of an inch. Most likely from a curb strike or pot hole in the road. Anyway the final solution was to bend the axle back into alignment with a chain and hydralic jack laid horizontally on wooden blocks. . I had my wife hold a straight edge along all three tires and I applied pressure with the jack untill they were all in three in alignment. Now it's time to shop for D rated tires and 15" rims.
    Thanks again to ColoradoDiablo for the help and advice!
    Regards,
    Rick
    Old 07-20-2012, 10:37 PM   #13
    Glad it worked out for you brit !
    Larry
    Trailer Spare Tire Location Douglas Alderman Trailering and Tow Vehicles 4 01-10-2012 01:41 PM
    need a new trailer racer3737 Original Mariah Talk 2 08-23-2011 07:40 PM
    need a new trailer darkcalling Trailering and Tow Vehicles 32 07-27-2011 12:32 AM
    Spare tire mount on a 1996 Chariot Trailer scubydo Trailering and Tow Vehicles 3 07-25-2011 06:20 PM
    My trailer fix Mark Original Mariah Talk 0 09-09-2008 11:39 AM
    There are 217 users
