Master cyl, for boat trailer
Trailering and Tow Vehicles
Old 06-27-2011, 02:02 PM   #1
karmann is currently offline
Send karmann:
Default Master cyl, for boat trailer
Hello All
I need a master cyl. for my chariot trailer. Its a 1995 272 barchetta, W/chariot trailer.
any suggestions as to where to get a master cyl?
thanks
PS, its a surge brake.
  • Old 06-27-2011, 03:22 PM   #2
    Tawakoni Paul is currently offline
    My Model: 2350Z
    My Engine: 7.4L Bravo 1
    Send Tawakoni Paul:
    Default Re: Master cyl, for boat trailer
    I bought mine at Redneck trailersupplies. Call them or take yours to them.
    Old 09-13-2011, 09:47 PM   #3
    BERTICUS's Avatar
    BERTICUS is currently offline
    My Model: Davanti 205
    My Engine: 5.7 Merc Cruiser
    Send BERTICUS:
    Hi all, I have a 94 Davanti 205 with brakes... the cylinder looks dry the hubs are greased they have buddies on and i don't know if the brakes even work... advice and suggestions welcome from servieing at winterization to just add brake fluid... feel free to e-mail team5sv@yahoo.
    thanks
    bert
    Old 09-13-2011, 11:01 PM   #4
    My Model: 2350Z
    Send Tawakoni Paul:
    I suggest that you go ahead and add brake fluid so you can check the operation of the master cylinder and see if the wheel cylinders leak. The wheel cylinders will probably leak, especially if they were dry. The hard part is working the master cylinder so you can bleed the system. I chock the wheels and put the vehicle in forward and reverse just enough to move the master cylinder as if activating the surge brake. You will need a bottle with a hose in it to catch the brake fluid as it comes out of the wheel cylinder bleeder fitting.
    Good Luck!
    Old 10-08-2011, 01:08 AM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    You can usually use a large screw driver to pry the master cylinder actuator rod back and forth rather than use the tow vehicle. Chances are if the master is dry, you have a rusted through brake line or a cracked hose. Either way, if you fill the master with brake fluid and work it back and forth...you should find your problem pretty quickly.
    I've purchased numerous trailer replacement parts from an online catalog company called Champion Trailer
    Happy Hunting
    Steve
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    New Boat Trailer dwmax Trailering and Tow Vehicles 4 11-11-2010 01:37 AM
    Boat cart - NOT trailer IowaWing Original Mariah Talk 2 02-02-2010 10:01 PM
    Trailer boat with bimini rooperdan Trailering and Tow Vehicles 5 05-13-2009 01:56 AM
    Boat Trailer Frame Steps Douglas Alderman Trailering and Tow Vehicles 3 12-03-2008 09:51 AM
    lifting boat off trailer Mark General Maintenance 7 04-25-2008 02:53 PM
    There are 309 users
