Sierra Trailering Clips?
Trailering and Tow Vehicles
Old 06-13-2010, 07:09 PM   #1
dakotaman728 is currently offline
My Engine: 4.3LX w/ Alpha 1
Send dakotaman728:
Default Sierra Trailering Clips?
Do any of you use Sierra 18-9099 trailering clips with your alpha drive? Would you use these in conjunction with a transom saver?
  • Old 06-14-2010, 04:25 PM   #2
    il_Mio's Avatar
    il_Mio is currently offline
    My Year: 2008
    My Model: SX18
    My Engine: 3.0L TKS - Alpha I
    Send il_Mio:
    Default Re: Sierra Trailering Clips?
    I use the trailering clips (which I have cut towards the specs for an Alpha drive with annodes on the hydraulic pistons ), I don't use them with a transom saver as I don't see the point in having both.
    Kindest regards,
    Johan
    Old 06-14-2010, 07:55 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    +1, I use the clips and don't use a transom saver.
    The advantage of a transom saver is that it is supposed to transfer the load of the drive bouncing around to the trailer rather than the transom, the clips can't do that. But, with power trim you'd have to take the pressure off the rams after installing the transom saver and I'm not even sure how you could even do that effectively. Transom savers seem best served on outboards and aluminum boats to me.
    Old 06-16-2010, 12:35 PM   #4
    Send dakotaman728:
    Thanks for the input!
    Using a boat cover support while trailering? dakotaman728 Trailering and Tow Vehicles 4 06-11-2010 10:30 PM
    Sierra Parts? DougR General Maintenance 0 08-30-2009 08:36 PM
    Trailering with Bimini Top being up. Douglas Alderman Original Mariah Talk 7 04-29-2008 12:26 AM
    Trailering my boat jchemotti Original Mariah Talk 2 11-04-2007 11:04 PM
    Trailering Tips MariahMan Trailering and Tow Vehicles 7 10-14-2007 11:00 PM
    There are 315 users
