Trailer repair advice
Trailering and Tow Vehicles
Old 05-16-2008, 10:25 PM   #11
I think I'd spend the extra $$ and buy some pressure treated plywood. You can buy "marine carpet" at many places, I think even Home Depot.
  • Old 05-16-2008, 10:58 PM   #12
    Send bpfirrman:
    I will check HD. Sould I remove the diamond plate over the wheel well while I am at it and add some other non slip surface that won't damage the underside of the boat?
    Old 05-19-2008, 03:04 AM   #13
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    For the trailer bunks make sure you use pressure treated lumber and galvanized bolts. (Replace whatever bolts and bunks are on there now or at least look at them with a very jaundiced eye.)
    As to the wheel wells I would see if you can pick up pressure treated siding or exterior grade plywood at Lowes or Home Depot. One sheet should do you fine.
    I would then cover it with complementary or matching marine grade carpet - I googled and got quite a few entries.
    Let us know how you progress on this.
    Brent
    1995 Talari Z240
    7.4L Merc, Bravo III Outdrive
    Corsa Performance Captains Call Exhaust
    Samson Sports Tower
    Old 06-04-2008, 11:53 PM   #14
    Send bpfirrman:
    Finally got my noisy trailer fixed today, turns out the grinding sound was indeed the brakes. The pad had worn down and it was rubbing metal to metal, brakes had probably never been replaced. Unfortunately the drum on the starboard side was shot, needed to be replaced. My mechanic got a good deal on 2 completely new drums assemblies with new bearings, $120 for the pair. After labor and a $25 trip charge and antoher $30 in parts the whole shabang was $500. He probably over charged me a bit on the labor(4 hours) but he did come to my house to do the repair.
    Old 06-05-2008, 01:08 PM   #15
    Hey bpfirrman,
    Glad to hear you found your trailer problem and got it fixed! Now get out there and get your Mariah wet!!
    Old 06-08-2008, 04:21 AM   #16
    MariahPD is currently offline
    Send MariahPD:
    Chariot Trailers were made of top quality products and are definately a top of the line unit. The fender pads should definately be recovered and replaced as they offer protection to the hull from road bebris the tires may kick up. The carpet should be a high quality carpet, at least 28 oz. carpet. The bunks should be carpeted with the same (good quality) carpet.
    How do you load and unload your boat, how far down do you back the trailer to load and unload? Do you spay anything on your carpet to help the boat slide on and off easier? All of these things add to extended carpet life of the trailer and make it much easier on the hull.
    Trailer Repair joez200 Trailering and Tow Vehicles 3 04-06-2009 10:28 PM
    New Member looking for some advice WolfProperties Original Mariah Talk 25 04-09-2008 09:00 PM
    Advice for the retired Colin T Chit Chat/Off-Topic 0 02-20-2008 07:45 AM
    Thanks for all your advice Colin T Chit Chat/Off-Topic 4 01-04-2008 06:48 AM
    Need Advice Please Sheli Sea Fox - Mariah Talk 6 07-23-2007 01:43 AM
    There are 264 users
