182 Barchetta 4.3L Tongue Weight
Trailering and Tow Vehicles
Old 08-27-2015, 05:54 PM   #1
Smokymance's Avatar
Smokymance is currently offline
My Model: 182
My Engine: 4.3L MerCruser Alpha 1
Send Smokymance:
Post 182 Barchetta 4.3L Tongue Weight
Doing a bit of searching, and I believe my 182 Barchetta with the 4.3L v6 alpha one vessel + trailer should be somewhere around 3000lb...its on a single axle Eagle trailer...I have as level as i can get it with a 2" drop.
At this overall weight, what kind of tongue weight should i see? When boat is parked level, i can grab the tongue and lift it around, so i decided to measure it with a bathroom scale...it came around 110-120lb...does that sound about right?
I never take it for long trips, just small trips to the local lakes.
Reason i ask is due to a long trip im taking soon as when i drive it around town, i do feel a slight slight jerking as it seems like the boat might be wanting to lift up on the tongue vs pushing down on it...or this might be a normal single axle trailer trait?
I tend to over think things so just wanted to get you guys opinion.
Thanks in advance.
182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
  • Old 08-27-2015, 08:26 PM   #2
    Default Re: 182 Barchetta 4.3L Tongue Weight
    Recommended tongue weight is 10% minimum and 15% maximum on a single axle trailer. You should be somewhere around 225 - 250lbs.
    RECOMMENDED HITCH WEIGHT PERCENTAGES
    TYPE OF TRAILER PERCENT OF WT. ON TONGUE
    Single Axle 10% minimum/15% maximum
    Tandem Axle 9% to 15%
    Travel Trailer 11% to 12%
    5th Wheel 15% to 25%
    Old 08-28-2015, 12:38 AM   #3
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    Thank you. That's what I have been reading too. Wonder why the boat came balanced out like that. Seems like it's been like that since new.
    Old 08-31-2015, 01:39 PM   #4
    Smokymance's Avatar
    My Model: 182
    Send Smokymance:
    Added a spare to the front of the trailer, close to the tongue, and that got me to about 165lb tongue weight, so getting closer to the ideal weight...i can adjust the front winch arm assembly back and fourth, and seems like i can scoot it forward about 2" before my trim tabs even touch the rear bunks if the boat is too forward..that should help as well.
    tongue weight. trailer.
    Fold away Tongue?? gahooligan Original Mariah Talk 2 02-07-2014 03:41 PM
    Barchetta weight vman Original Mariah Talk 29 09-07-2013 10:05 PM
    94 180 Talari tongue weight? tshaull Original Mariah Talk 7 04-13-2012 05:33 PM
    Weight bisket Chit Chat/Off-Topic 8 08-06-2011 08:33 PM
    what is the weight eric w Original Mariah Talk 3 01-04-2010 08:15 AM
    There are 252 users
