94 180 Talari tongue weight?
Old 04-10-2012, 11:18 PM   #1
tshaull is currently offline
My Model: z212 shabah
My Engine: 5.7lL 350 mag
Send tshaull:
Default 94 180 Talari tongue weight?
New owner of a 94 180 talari on a heritage trailer. My vehicle has an 1 1/4'' hitch need to know if I need to buy a 2'' hitch or if 1 1/4'' hitch will do with 300lbs max tongue weight. Thanks
  • Old 04-11-2012, 12:56 AM   #2
    Default Re: 94 180 Talari tongue weight?
    I use a 2" ball hitch rated for 3500 lbs for my 180. That boat & trailer combined will be right around 3000lbs so i'd suggest you are safer with a 2". Its the boat & trailer weight, rather than the tongue weight, that's really the issue when choosing a hitch.
    ColoradoDiablo likes this.
    Old 04-11-2012, 04:54 PM   #3
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    what type of tow vehicle is the hitch mounted on? 1 1/4" receiver hitches are usually mounted on smaller vehicles with lower tow ratings.
    Old 04-12-2012, 11:47 PM   #4
    Send tshaull:
    It is a gmc safari van. I can buy a 1 1/4" male end with a 2" ball on it I was just wondering if that would be fine or if I need to buy a whole new 2" hitch
    Old 04-13-2012, 12:53 AM   #5
    What's the tow rating for the Safari ?
    Old 04-13-2012, 11:15 AM   #6
    Send tshaull:
    5500 lbs
    Old 04-13-2012, 02:23 PM   #7
    Not trying to be negative but....it might tow it fine , but is it going to pull the boat out of the water? I wouldn't want to try and pull a 5500 lb trailer with it , Much less try and stop it.
    JMO
    Larry
    Old 04-13-2012, 05:33 PM   #8
    With a 5500lb tow capacity it should tow a 180 & trailer (approx 3000lbs) reasonably well. You might get away with the present 1.25" tow bar but for safety i would seriously consider upgrading to a full class 2 tow hitch. Trying to stop a 3000lb boat/trailer without electric brakes in a panic situation with the smaller hitch is not something you want.....
    Weight bisket Chit Chat/Off-Topic 8 08-06-2011 08:33 PM
    Weight of '95 180 Talari Talari95 Original Mariah Talk 16 07-14-2010 03:39 PM
    93 Talari weight Snowaterdude Original Mariah Talk 8 02-20-2010 12:12 AM
    what is the weight eric w Original Mariah Talk 3 01-04-2010 08:15 AM
    1996 Z235 Talari weight rssniff Original Mariah Talk 3 03-18-2009 12:02 AM
    There are 244 users
