Surge Brakes Parts
Trailering and Tow Vehicles
Old 06-16-2015, 04:00 PM   #11
cswinings is currently offline
My Model: z240
My Engine: 7.4
Send cswinings:
Default Re: Surge Brakes Parts
So I went through a similar process last week. I had not tested the brakes on my trailer yet since I had bought it last july and pulled it with an F350.. you can't hardly tell its there anyway. But this winter I traded in my F350 for a SUV, so I need to check the functionality of my surge brakes. They just plain didn't work. Good news is the actuator wasn't dry.. and still worked. Bled the lines.. lots of air came out and then when i test the brakes again.. found that the old cylinders were all seized up and wouldn't release so now the brakes were dragging. So couple wheel cylinders later for O'reily auto parts and now I've got good breaks!
I would like to either upgrade to a free-backing system or electric down the line but this should do for now. I've been hemorrhaging money on this boat this year. New tires, new brake parts, bimini, partial camper, mooring cover, new batteries, stereo.. sheesh, hopefully time to just enjoy this boat now.
  • Old 06-20-2016, 01:10 AM   #12
    My Model: Z276
    Send Brian Belcher:
    Reviving this....
    Who knows how to get the actuator out of the bigger, triple axle Chariot trailer ?
    tbrookens and Firestone like this.
    Old 06-23-2016, 06:17 PM   #13
    All depends on the make of the actuator. Not sure what brand comes on the Chariot. Etrailer.com should have the parts for the rebuild or replacement actuator. They also have videos on their site to show you how.
    Sent from my XT1585 using Tapatalk
    Old 06-24-2016, 04:24 AM   #14
    My Model: Z276
    Send Brian Belcher:
    I've just made the final decision. I'm converting to electric. $160 for the 4 backing plates and some wire and a plug. I'm going to drill a 3/4" hole completely through the actuator/sliding tongue and put a grade 8 bolt to lock it down. I prefer the surge becase they are way more powerful. I can lock the tires up with a surge. Ain't happening with e-brakes.
    Two things I don't like about surge are on a very steep down hill, the surges want to put the brakes on and sometimes it's too much. The thing is the backing up.
    The down side to e-brakes-not nearly as strong as surge.
    Old 08-11-2017, 12:02 AM   #15
    Reaper22 is currently offline
    My Model: Z212
    My Engine: 350 Magnum alpha one
    Send Reaper22:
    Originally Posted by Brian Belcher View Post
    Reviving this....
    There are e-clips inside on the shaft, Dealer told me to remove external snap rings on the outside and pry e-clips out from inside and pin will come out, I'm guns put 3/4 bolt thru mine because I pull with my truck and don't figure I need them as long as I am careful getting to the lake... I will fix them this winter...
    Old 08-11-2017, 02:11 AM   #16
    My Model: Z276
    Send Brian Belcher:
    I'm certain we arenot talking about the same trailers cause it was not a simply pulling e-clips. I had to hole saw 4 holes to get at the 4, 3/8" bolts that held the master cylinder in. It wasn't too terribly hard, just had to be precise on the location of the four holes.
    Surge brakes tom112 Trailering and Tow Vehicles 1 01-11-2015 07:00 PM
    Surge Brakes jarwiebe Trailering and Tow Vehicles 1 08-29-2012 12:47 AM
    Brakes darkcalling Trailering and Tow Vehicles 2 06-09-2011 08:42 PM
    I want to add brakes to the third axel lindajmonahan Trailering and Tow Vehicles 0 08-24-2010 11:28 PM
    Need surge brake cap bpfirrman Trailering and Tow Vehicles 4 07-28-2008 04:45 PM
    There are 253 users
