To balance or not to balance
Trailering and Tow Vehicles
Old 07-28-2017, 02:57 PM   #1
Tlolesen's Avatar
Tlolesen is currently offline
My Model: 182
My Engine: 4.3 merc
Gallery Images: 3
Send Tlolesen:
Default To balance or not to balance
I have a single axle trail rite trailer with a 2001 Shabah 182. I need new tires and wanted some opinions on wether to balance the new tires or not. The existing ones were balanced. Iam new to boating and have not towed much before the last 3 months.
  • Old 07-28-2017, 03:03 PM   #2
    Default Re: To balance or not to balance
    That's a good question. I suppose I never thought about it as Discount Tire just balanced mine without asking. Apparently it's not necessary on trailer tires per eTrailer.com. (They have been a go to place for my trailer questions).
    https://www.etrailer.com/question-59617.html
    Sent from my XT1585 using Tapatalk
    Old 07-28-2017, 03:41 PM   #3
    My Model: Z202
    Send Firestone:
    Did you check the age of the tires? It is a 4 digit code stamped on the side wall. 1st two digits are the week it was made and the 2nd two are the year. If they are over 5 years old the should be replaced. I have a buddy that gets new ones every 3 years.
    John
    Old 07-28-2017, 05:02 PM   #4
    tdicamillo is currently offline
    My Model: Z222 Shabah
    My Engine: 7.4L Bravo I
    Send tdicamillo:
    I always balance. An out of balance tire can wear bearings out faster.
    Old 07-28-2017, 09:36 PM   #5
    My Model: Z276
    Send Brian Belcher:
    Balance
    Old 07-29-2017, 02:02 AM   #6
    zrbart2000 is currently offline
    My Engine: 4.3 alph LH
    Send zrbart2000:
    Don't even think about it, Just do it.
    Old 07-29-2017, 12:41 PM   #7
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    The tires are 4 years old but 1 blew out last week. I had a new spare but the other tire on the trailer is the same as the one that blew so I'm going to get 2 new ones for the trailer,my spare is a bias and the new ones I am going to get will be radials so I will balance them.
    Old 08-03-2017, 12:56 PM   #8
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    I got 2 new tires and when I installed them I noticed that when the tire blew it smashed the metal brake line. I am not sure if the surge brake was working before but pretty sure it won't work properly now. With a boat this size do you think brakes on the trailer are really necessary, helpful yes but necessary?
    Old 08-03-2017, 11:28 PM   #9
    Sookie is currently offline
    My Model: 182 Shabah
    My Engine: 4.3 mercruiser
    Send Sookie:
    Hello we have a 1999 182 Shabah (got it a month ago and have loved it from the test ride/drive) it came with the original Prestige trailer. No surge brakes on it at all and have no problems towing it at all with our Tacoma. As long as you tow smart and careful you should have no problems. Cheers and hope this helps
    SX 18 boat balance bakdraft Sea Fox - Mariah Talk 18 08-29-2008 12:49 PM
    There are 250 users
