Performance question
Sea Fox - Mariah Talk
Old 11-14-2013, 11:42 AM   #1
bboy012003 is currently offline
My Year: 2006
My Model: SX21
My Engine: 5L Alpha One
Send bboy012003:
Default Performance question
Just bought a low hour/used 2006 Mariah SX21 in a situation where there was no opportunity to get it in the water. The boat has a 5.0L carbureted merc with a 21 pitch prop. Fuel injected my have been a better buy! ?
Question: With this set-up, will the boat have much of a hole shot to pluck a skier or wake boarder. My concern: a couple of friends have boats that cant get it up, just too big with no low end pull. Appreciate your thoughts.
  • Old 11-14-2013, 02:56 PM   #2
    jbland's Avatar
    jbland is currently offline
    My Year: 2006
    My Model: SX 21
    My Engine: 5L, V8, I/o
    Send jbland:
    Default Re: Performance question
    I have the same boat with the 5.0L V8. It has PLENTY of power to get skiers/wakeboarders up. I also put a monster tower on mine a few seasons ago and it works great.
    Old 11-14-2013, 03:14 PM   #3
    The engine isn't always a limiting factor. Switching to a 4 blade prop will give you a lot more holeshot. Visit the "Prop Talk" section of the forum, our prop gurus can get you set up with exactly what you need.
    bboy012003 (11-14-2013)
    Old 11-14-2013, 06:26 PM   #4
    I have an SC21 with the 4.3 and a 17p 4 blade. It pulls skis, wake boards an tubes no problem. I don't recall doing that with more than 5-6 people in the boat bit the 5.0 should do fine. Especially being an open bow to adjust the weight to.
    Old 11-15-2013, 03:36 AM   #5
    rainman55343 is currently offline
    My Year: 2003
    My Model: sx 19
    My Engine: 5.7 alpha 1
    Send rainman55343:
    I have a 5.7 merc with a 4 blade 19p prop.that's what I would recommend.
    Old 11-16-2013, 06:25 PM   #6
    My Year: 2006
    My Model: SX21
    Send bboy012003:
    What is your top speed with 19 pitch prop and at what RPM, thanks, dave
    Old 11-16-2013, 06:35 PM   #7
    My Year: 2003
    My Model: sx 19
    Send rainman55343:
    God I can't remember. Around 4800 with top speed of 52 to 54.
    Thank you rainman55343 for this useful post!
    bboy012003 (11-17-2013)
    Old 11-17-2013, 01:10 PM   #8
    My Year: 2006
    My Model: SX21
    Send bboy012003:
    May I ask where is a good place to buy a prop is?
    Old 11-17-2013, 03:02 PM   #9
    IBoats usually runs some good deals on props , but if at all possible try to find a dealer near to you that will "loan" props for testing. Then you can dial it in the way you want.
    272 performance rickvr Boating 101 0 08-12-2012 02:05 PM
    2000 - 258 7.4L/BIII performance dbez Boating 101 2 05-06-2011 09:57 AM
    182 performance question bbrophy58 Original Mariah Talk 2 11-26-2009 02:50 PM
    212 engine performance dieselwiezil Original Mariah Talk 20 06-19-2008 04:58 PM
    Performance of Shabah Double D Original Mariah Talk 2 07-17-2007 07:37 PM
    There are 253 users
