2000 - 258 7.4L/BIII performance
Boating 101
Old 05-05-2011, 04:12 PM   #1
dbez is currently offline
My Model: 258
My Engine: 7.4L Bravo 3
Send dbez:
Default 2000 - 258 7.4L/BIII performance
Just realised I should start he tread in the appropriate place.
Just looking for general info on fuel usage, quirks, gotchas or any thiing of that nature. I ask especially since this boat has very low hours (72) and is 11 years old. Dredd sugested that i have it scaned to verify the hours which is a good idea but looking for other comments on things that I might not think of. This is my first big boat.
Thanks in advance,
Bez
  • Old 05-05-2011, 06:35 PM   #2
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Default Re: 2000 - 258 7.4L/BIII performance
    I found shortly after purchase that the power lift resi was low on fluid and set off the beeping alarm. I had the whole system flushed and re-filled. no more beep. the resi is under the back of the motor/trans
    change the outdrive water pick up pump impeller, unless they can show it being done in the last year. if it fails, you over heat and there goes the motor. this is something you should do every other year like clock work.
    2000 Z302 Bow Rider
    Thank you Oregondunes for this useful post!
    dbez (05-06-2011)
    Old 05-06-2011, 09:57 AM   #3
    My Model: 258
    Send dbez:
    Every bit helps...thanks
    Bez
    Corsa Performance Silent Choice Exhaust bdbyrnes Original Mariah Talk 17 03-24-2010 12:58 AM
    182 performance question bbrophy58 Original Mariah Talk 2 11-26-2009 02:50 PM
    212 engine performance dieselwiezil Original Mariah Talk 20 06-19-2008 04:58 PM
    Performance of Shabah Double D Original Mariah Talk 2 07-17-2007 07:37 PM
    There are 304 users
