Depth Guage Frquency?
Sea Fox - Mariah Talk
Old 02-25-2008, 05:13 PM   #1
bakdraft is currently offline
Send bakdraft:
Default Depth Guage Frquency?
Hi All,
My first.... post!
Just bought my first ever boat.. A brand new SX18 with the new twin full stripe Hull (Aztec Yellow)
I has the option pack with the Digital depth guage fitted. As I have a Garmin 550s with its own sounder, I am concerned about them clashing. The Mariah transponder is fitted exactly where the Garmin transponder wants to be.
So has anyone ever fitted two transponders sisde by side, if so, do the interfere.
Could you just use the garmin unit and split its signal to both head units?
The Garmin is a 50/200 hz unit, but does anyone know what frequency the Mariah unit is?
Who makes the unit for Mariah?
Garmin say try setting the units at least 50hz apart.... but as I do not know what the Mariah unit is set to, I can't try that.
Any help / thoughts would be appreciated
Dave
  • Old 02-25-2008, 05:24 PM   #2
    Welcome to the board Dave, and congrats on your new boat!!
    Can you post a pic of your depth gauge? I'm not sure who makes the new gauges, but the old Mariahs used depth gauges from both Lowrance and Faria Instruments. Once we figure out who makes the depth gauge, we can figure out more about the transducer specs.
    If you have access behind your dash, try and find your depth gauge. There should be one thick black wire going into it. This is your transducer line, follow it, and there should be a small tag somewhere listing what model transducer it is. My Lowrance 3500 has a Gray connector about the size of my thumb, and a small silver tag on it which says "PD-N Transducer". If you can find the code, this will help locate the specs on it!
    We'll try and help you get this all straightened out, just keep us updated with what you can find! There's not a lot of documentation on the new Mariahs, so we'll help you figure it out!
    Old 02-25-2008, 08:33 PM   #3
    Send bakdraft:
    Hi !
    Thanks for your really cordial, swift reply.
    As it happens my boat is due to arrive next weekend, so I can't check out the cables just yet.... but when I visited it last week I took plenty of photos.
    I have attached one of the guage, it appears not to have any markings... but the general guages are indeed Faria.
    Dave
    Old 02-25-2008, 10:55 PM   #4
    Send bakdraft:
    Default Sorted!!
    Hi again,
    As it happens I have managed to solve my own problem.
    Whilst I was taking my (80!) photos of the boat before I bought it, I happened to point the camera upside down behind the dash board and took a photo. Amazingly it perfectly took a shot of the back of the depth finder revealing its code of HDR610.
    A quick Google reveals its a Humminbird HDR610. From this I could get the owners manual and found out it is a 200khz.
    The Links and then specs are below:
    A Shop that sells them
    The owners manual
    Humminbirds web page for the product
    Key Features:
    Reliable Digital Depth for all Boat Users
    Tracks Bottom Up to 70 MPH
    Includes White and Black Color Face Plates and Bezels
    Easy to Install into Existing 2 1/8 inch gauge opening
    Wires to Ignition Switch for Auto Power On
    Rubber Buttons for Greater Reliability
    Backlight for Use at Night
    Shallow and Deep Depth Alarms
    Reads in Feet, Meters and Fathoms
    Display: 1 1/4" Diagonal, High Contast FSTN
    Transducer Standard: Single Beam
    Transducer Coverage(s): 20ø @ -10db
    Operating Frequency(s): 200 kHz
    Power Output: 1600 Watts Peak-to-Peak, 200 Watts RMS
    Depth Capability: 600 feet
    Target Separation: 2 1/2 inches
    Temperature: Not Capable
    Speed: Not Capable
    Power Input: 10-20 VDC
    Unit Mounting: In-Dash
    Unit Size Installed (In-Dash): 2.42" D x 4.75"
    Transducer Mounting: Transom Mount
    I thought this might be useful for others!
    I will let you all know how I get on with the boat and the pair of Transponders!
    Great result for a first post
    Old 02-26-2008, 12:15 AM   #5
    Wow, nice job! I'm sure it will help others out too! Way to go!
    Old 02-26-2008, 12:25 AM   #6
    I concur, excellent first draft and follow up bakdraft!
    BTW, just wondering from you user name, are you a Fireman??
    Old 02-26-2008, 03:00 PM   #7
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Great first post Bakdraft, tell you what, taking photos of the back of your dashboard is REALLY taking photography of your new boat to the max
    I LOOKED behind mine once, hmmmm wont be doing that again in a hurry.
    Looking forward to you posting some pics of your beautiful boat.
    Welcome aboard.
    Tony
    Perth, Western Australia
    Old 02-26-2008, 08:48 PM   #8
    Send bakdraft:
    As it happens there is a relationship to the film Backdraft spelt with a 'c' but it is not that I am a fireman.
    It so happens, that back in 1991 when the film was released, the internet was pretty much uknown in the UK. I was an early starter and in those days you had to have an 8 letter name - you could not use your own name - and so I thought I would use the film I had seen the night before... but had to drop the 'c' to make it 8 letters.... and it has stuck ever since...... so when you see bakdraft on the Tivo forum or E90 forum or AVSforums forum et al..... you know who it will be... cause its a one off!
    Bakdraft..... nee Dave
    Old 02-27-2008, 12:31 AM   #9
    and here i thought it had something to do with 'flatulence'....
    depth sounder? dieselwiezil Original Mariah Talk 7 04-25-2008 07:51 PM
    Depth Sounder too! moondance100 Original Mariah Talk 3 04-24-2008 07:19 AM
    mystery guage on dash panel? 2005expedition Original Mariah Talk 2 03-19-2008 03:10 PM
    Depth sounder combo units ... suggestions? 180diablo Original Mariah Talk 32 03-18-2008 11:25 PM
    depth meter harry van kesteren Original Mariah Talk 6 09-13-2007 10:14 AM
    There are 318 users
