Carburetor problem?
Sea Fox - Mariah Talk
Old 05-15-2012, 10:16 PM   #1
partymarty is currently offline
My Year: 2003
My Model: SX25
Send partymarty:
Default Carburetor problem?
I have a 2003 Mariah SZ25. Last year boat ran great & had it winterized. Opened the boat with a full tank of gas and tried to start it. Seems that the carburetor isn't getting gas. Any suggestions?? Gas filter or pump?
  • Old 05-16-2012, 05:34 PM   #2
    danwndsurf is currently offline
    My Model: Shabah 202
    My Engine: 5.7 Alpha One
    Send danwndsurf:
    Default Re: Carburetor problem?
    A guy last summer had the same problem...His kill switch (red string with black horse-shoe looking part) had pulled out. Hopefully that's your issue. Or put your battery on a drip over night and see if that helps.
    Old 05-16-2012, 09:42 PM   #3
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    I'm assuming you have an electric fuel pump. When you turn on the key, you should hear the pump run for a second. This might take a second person sticking their head down under the back seat next to the pump. If the pump doesn't run, check to see if the pump is getting power. If it's getting power and not running, then it's a bad pump. If it's not getting power then start checking relays/fuses/connections, things of that nature. If it's running, but still no fuel in the carb, check filters/injectors.
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 03-23-2015, 06:18 PM   #4
    travelmike123's Avatar
    travelmike123 is currently offline
    My Year: 2006
    My Model: DX 212
    My Engine: 150 HP OB
    Send travelmike123:
    All you need to start a boat is spark, gas, and compression. Check for all three.
    There are 359 users
