SX19 - Speedo
Sea Fox - Mariah Talk
Old 03-03-2012, 06:00 PM   #1
poyntoncat is currently offline
My Year: 2006
My Model: 19sx
My Engine: 4.3l merc
Send poyntoncat:
Default SX19 - Speedo
and no, i am not talking about very tight swimming trunks form the 1970's..
So i am in my first week as a boat owner, and my wife tells me that she already feels widowed.
Todays challenge - my speedo does not work..
I am slightly "technable" which means i can turn my hand to most things, and i understand the pitot principle by which the speedo works, and i have read the threads (very good i might add..) regarding cleaning the tube and the passage through the lower outdrive unit - which i seem to be able to pass a small wire through, BUT, i don't have access to an air compressor to test the tube.
can i disconnect and test the speedo by simply blowing in it? should the needle move? and why does it have wires attached if it is just a simple pitot.
heeeeeelllllllpppppppppp!
  • Old 03-03-2012, 10:01 PM   #2
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Default Re: SX19 - Speedo
    The wires are for the light inside the speedo for night time boating. I pulled the tube off the back of the speedo and was able to blow through it just with my mouth, of course it didn't seem like it was doing anything but my daughter watched the pitot port on the stern dive and said water was coming out of it and after the water quite she could feel air coming out of it. Now if it had been restricted I suppose my approach wouldn't have worked.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 03-03-2012, 11:00 PM   #3
    My Year: 2006
    My Model: 19sx
    Send poyntoncat:
    Hey great advice Jake, coming at the challenge from the opposite direction!
    I disconnected at the speedo, blew towards the back - no joy. I tried to blow through the entrance hole on the base of the stern drive - no joy. I disconnected the pipe at the top of the lower unit, and blew from the speedo end - we have air! so i went at cleaning the hole out with a little more vigor, and (hopefully...) hey presto - once all connected back up, i can blow all the way through, so we will see what happens back on the lake tomorrow....
    thanks again.
    Speedo USN Mariah owner General Maintenance 2 09-06-2010 06:40 PM
    Help with the speedo guys embasun Original Mariah Talk 2 01-31-2010 07:46 AM
    Speedo problem embasun Original Mariah Talk 8 01-19-2010 02:00 PM
    Borken Speedo cometb Original Mariah Talk 8 09-29-2009 07:13 PM
    Speedo Repair bpfirrman Mercury MerCruiser 14 04-29-2008 06:04 PM
    There are 216 users
