horsepower at the propellor
Sea Fox - Mariah Talk
Old 03-30-2010, 07:51 PM   #1
Roberto is currently offline
My Year: 2007
My Model: sx22
My Engine: 4,3L alpha one Gen11
Send Roberto:
Default horsepower at the propellor
Hello there,
I have bought a SX22 limited edition from the year 2007.
It has a mercruiser 4,3L on board.
My question is: how much horsepower do I have on the propeller?
and what exactly means "turn key start".
  • Old 03-30-2010, 08:20 PM   #2
    Default Re: horsepower at the propellor
    Hi Roberto,
    Not sure how much HP loss there is through the outdrive, but I would figure it's probably 10% at the most. That said, I believe your 4.3L puts out 190hp for the standard model and 220hp for the MPI at the motor.
    If your looking for advice on the best prop to use, shoot a post over to our resident prop guru, MikeyT and he'll gladly get you going in the right direction.
    Not knowing in what context the phrase "turn key start" was used, it could simply mean you use a key to start the motor verses a keypad ignition system (there's no way you could "pull start" this motor) or it could mean she's ready to go, just fill 'er up. turn the key and have fun...
    Old 03-30-2010, 08:38 PM   #3
    My Year: 2007
    My Model: sx22
    Send Roberto:
    Thank you for the information
    Old 03-31-2010, 03:18 AM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    "Turn Key Start" is MerCruiser's proprietary name to their carbureted engines that supposedly don't require you to pump the throttle to engage the choke. I have a friend with one and it doesn't seem to do much. His is hard to start and actually starts easier when manually choked. I'm thinking "Marketing 101" at it's best.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    93 5.0 LX Thunderbolt Alpha 1 Horsepower Snowaterdude Original Mariah Talk 7 09-30-2009 12:21 AM
    horsepower question PROPNUT Mercury MerCruiser 4 03-19-2009 03:12 AM
    There are 287 users
