2004 sx19, 4.3 me rc alpha 1 drives in reverse
Sea Fox - Mariah Talk
Old 06-15-2016, 10:25 AM   #1
Firecattraxf6 is currently offline
My Year: 2004
My Model: Sx19
My Engine: 4.3 bravo I
Send Firecattraxf6:
Default 2004 sx19, 4.3 me rc alpha 1 drives in reverse
My Mariah sx19 was bought used this spring. I did not run it on lake before buying. First time out realized it drives but only in reverse. It backs up but only in drive. In other words, I pull throttle back to go. Quizzed prior owner, he told me that was way he bought it. Being new to sport, he figured it was a Mariah thing. Any clues and help?
  • Old 06-15-2016, 11:42 AM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 2004 sx19, 4.3 me rc alpha 1 drives in reverse
    Does it have a reverse rotation prop on it? What is the part number stamped on the prop?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-15-2016, 04:01 PM   #3
    My Model: Z202
    Send Firestone:
    It is not a Mariah thing to my knowledge.
    John
    Thank you Firestone for this useful post!
    Firecattraxf6 (06-15-2016)
    Old 06-15-2016, 06:29 PM   #4
    My Year: 2004
    My Model: Sx19
    Send Firecattraxf6:
    J 14.26 x 21 p....is that what you were referring to?
    Old 06-16-2016, 12:58 PM   #5
    My Model: Z280
    I was hoping it had a part number stamped on it so I could look up if it is a LH or RH model.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-16-2016, 03:27 PM   #6
    From the rear of the boat it should appear the prop should spin clockwise- if not the prop maybe a LH.
    Or someone may have taken the outdrive off and put it back onto the bellhousing wrong. There is a shift shaft that needs to be placed in a particular location prior to putting the outdrive back on.
    2004 sx19 Lucky14 Mariah Boats For Sale & Wanted 2 07-15-2014 01:34 AM
    2004 SX19 - Central VA Lucky14 Introductions 4 07-13-2013 03:16 AM
    4.3L Alpha 1 Noise in Idle from Reverse? Slash9point5 Mercury MerCruiser 9 04-17-2012 04:20 PM
    SX19 4.3 MPI alpha one WOT RPM?? jeandre Sea Fox - Mariah Talk 1 11-30-2011 06:28 PM
    There are 246 users
