Bravo 3 prop swap questions
Prop Talk
Old 08-11-2014, 02:06 AM   #1
My Model: Z258
My Engine: 7.4 & Bravo 3
Send 99 Mariah 258:
Default Bravo 3 prop swap questions
Hello all....
Bought a nice set of props from ebay. I also bought the new nut kit with washers and the prop wrench for Bravo 3's.......
Planning on installing them this week sometime but need some advice. My main concern is the prop being stuck on the shaft after I remove the nut. I've seen videos on youtube with people using pullers.... Are they cheap to buy or can I rent one....
Also was wondering how to lock the props when installing to torque the nuts down. Any info is appreciated......This will be my first prop swap..,
zgieb grzegorz likes this.
  • Old 08-11-2014, 01:28 PM   #2
    Hudson River Steve's Avatar
    Hudson River Steve is online!
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Bravo 3 prop swap questions
    I've never had an issue removing the propellers, they usually just slide right off. Worst case a slight tap with a piece of wood and a hammer. Propeller pullers are usually only required to remove props from tapered shafts that you would typically find on an inboard powered boat.
    To lock the prop while removing and installing, place a piece of wood beteen the tip of the propeller blade and the anti-cavitation plate on the outdrive. Make sure you lubricate the splines with Merc Spline grease before installing your new propeller set, torque the big nut to 100 ft-lbs and the small nut to 60 ft-lbs.
    99 Mariah 258 likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    99 Mariah 258 (08-11-2014)
    Old 08-11-2014, 01:35 PM   #3
    My Model: Z258
    Send 99 Mariah 258:
    Thank you.
    Old 08-15-2014, 08:19 PM   #4
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Do you worry about "timing" of the props, Steve?
    Old 08-15-2014, 08:23 PM   #5
    My Model: Z258
    Send 99 Mariah 258:
    Hello Dred......
    Can you explain. I was actually about to swap them out....
    Old 08-15-2014, 08:33 PM   #6
    Dredd's Avatar
    Send Dredd:
    Some people say that how they line up matters, other people say it doesn't matter. I would definitely respect whatever Steve says.
    The people that say to "time" them say that a blade on one prop should be straight up while a blade on the other prop is straight down. The problem with this from my experience is that since the blades are so wide it's hard to be very accurate. You can be a few splines off and one still appears up while the other appears down... if that makes sense.
    Old 08-15-2014, 09:31 PM   #7
    My Model: Z280
    There is no mention of how to align the propellers in the Mercruiser Bravo 3 service manual. That being said I usually install the large front propeller with the blades in the shape of a Y as I look at them from the rear. I then place the smaller rear propeller like an upside down Y. Seems to work for me.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Dredd (08-18-2014)
    Old 08-15-2014, 10:22 PM   #8
    My Model: Z258
    Send 99 Mariah 258:
    Thanks for the reply's but I'm in trouble ........went to the boat parked at my sisters house and the drive oil was coming out the drain plug hole.....opened her up and drive oil reservoir was empty...Stuck my head in there and there's drive oil under the drive shaft(guessing). Thinking it's the fitting that inserts into transom assembly. I'll post some pics and start a new thread. Thanks again
    Old 08-17-2014, 12:54 PM   #9
    My Model: Z280
    I really hope that you do not need to replace that fitting, it is very difficult to access on my boat. I replaced it and everything else on the transom assy a few years ago. I actually pulled the motor to get access to that fitting. I'm not as young and limber as I used to be. Hopefully it is just the hose.
    Sent from my iPad using Tapatalk
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-19-2014, 01:46 AM   #10
    My Model: Z258
    Send 99 Mariah 258:
    Hope so too....I can't even see the fitting....it has a huge water pipe and fitting above where it is blocking it......at this point I'm just going to give up and take it to my local mercruiser shop......I went in today and he said it would be a 2-3 hour job at $110 a hour.......Is that a normal rate? Thanks again HR Steve..
    Bravo III Prop Shaft Discoloration Humpty Prop Talk 10 07-29-2014 07:12 AM
    bravo 3 new prop shaft seals leaking Txtruckerpaul Mercury MerCruiser 15 05-05-2014 09:00 PM
    Bravo 2 prop on a alpha 1 drive? dieselwiezil Prop Talk 1 07-14-2010 08:15 AM
    bravo 3 prop question jgreen Prop Talk 5 07-29-2009 04:42 AM
    2350Z/454/bravo 1 prop selection cleah Prop Talk 3 06-03-2009 10:37 AM
    Total Members: 18,527
    Total Threads: 12,959
    There are 161 users
