bravo 3 prop question
Prop Talk
Old 07-28-2009, 12:59 AM   #1
jgreen's Avatar
jgreen is currently offline
Gallery Images: 2
Send jgreen:
Default bravo 3 prop question
Hi Guy's
I've searched the forum and several other sites and can't find the answer to this. How do you clock the bravo 3 props when installing?
I'm getting mine reconditioned next week and want to make sure they are on correctly.
Thanks!
Jay
  • Old 07-28-2009, 08:36 AM   #2
    Default Re: bravo 3 prop question
    Hi jgreen,
    They call it "indexing" the props. I remember reading somewhere that with the Bravo IIIs, you no longer need to index the props but if you what to do it, then this is how it's done:
    Install the front prop so the middle of one blade is pointing up in the 12 o'clock position and then install the rear prop with the middle of one blade pointing at the 6 o'clock position. From the rear, you should be able to see all six blades.
    12 and 6 o'clock, sort of like this:
    If installed correctly, none of the front blades or rear blades should ever meet together at the 12 o'clock position otherwise it has been said this can cause cavitation or vibrations through the outdrive.
    Don't forget to lube the shafts and prop splines and thrust washers before reinstalling the props.
    Old 07-28-2009, 03:05 PM   #3
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Thanks WetWilly, just what I needed. Couldn't hurt to index them like you show.
    Did your props come with the polished finish or did you have them done? They look great!
    Jay
    Old 07-29-2009, 01:45 AM   #4
    Hi jgreen, I had them polished when I had them reconditioned and balanced.
    Old 07-29-2009, 02:33 AM   #5
    mfitz62's Avatar
    mfitz62 is currently offline
    My Model: 2000 258 Shabah, 7.4L Bravo III
    Send mfitz62:
    These are the first ss props i have owned that are not polished. Any particular reason they don't come that way? Just curious.
    Old 07-29-2009, 04:42 AM   #6
    I would imagine it's got something to do with cost and satin finishes are easier to maintain (no waxing or polishing).
    Yet another prop question Mike S Prop Talk 6 06-05-2010 01:35 AM
    Prop Question karmann Prop Talk 5 08-05-2009 02:27 AM
    Prop Question ? karmann Prop Talk 8 07-01-2009 09:20 PM
    2350Z/454/bravo 1 prop selection cleah Prop Talk 3 06-03-2009 10:37 AM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    There are 280 users
