Mercury Spitfire
Prop Talk
Old 05-16-2014, 12:19 AM   #1
TAT Thread Starter
TAT is currently offline
My Model: z192 Barchetta
My Engine: 4.3L LX
Send TAT:
Default Mercury Spitfire
I have a 1995 Mariah Barchetta z192 with a 4.3lx. It runs great, however it's a dog coming out of the hole with or without pulling someone. I am currently running a 3 blade aluminum prop (not sure of pitch and size, its still in storage). I was looking at the mercury spitfire 4 blade, any suggestions? thanks for your time.
  • Old 05-16-2014, 03:14 AM   #2
    Default Re: Mercury Spitfire
    Need to know existing prop size and your WOT(wide open throttle) rpms now , before we can do you much good.
    Most are running a 20P 4 blade on that engine/drive combo , unless your at high altitude then I'd run a 17P.
    Old 05-17-2014, 03:27 PM   #3
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    I am currently running the following prop:
    Black Max #48-78122A40
    21P
    13 3/4"
    I believe my WOT was 4600 -4800. Thanks for your time.
    Old 05-17-2014, 03:44 PM   #4
    Your in the sweet spot as far as normal usage.
    You want more out of the hole , switch to a 4 blade 20P and add a set of SMART TABS.
    If your going to be doing a lot of skiing/tubing , gotta have the 4 blade.
    You'll lose a bit of speed on the topend , but it is well worth the tradeoff.
    It'll be a rocket out of the hole.
    Personally , I'd try the Smart Tabs first.
    Then add the prop after a good test day if you want more grunt.
    Old 05-17-2014, 07:06 PM   #5
    TAT Thread Starter
    My Engine: 4.3L LX
    Send TAT:
    Thank you for your time. We like to do alot of skiing and tubbing.
    Old 05-19-2014, 12:16 AM   #6
    dlockha's Avatar
    dlockha is currently offline
    My Model: Barchetta 182
    My Engine: 4.3l Mercruiser
    Send dlockha:
    I have a 21 pitch on my 1995 barchetta 180 with a 4.3l also I'm not worried about top speed most of the time will be spent pulling tubes or putting around the lake. I have read the sticky's and still unsure what I want I am leaning toward a 4 blade 19 or 18 would that put me too high rmps?
    Sent from my iPad using Tapatalk
    1995 Barchetta 182, 4.3lx mercruiser
    Old 05-19-2014, 01:06 AM   #7
    What is your WOT with the 21P?
    Old 05-19-2014, 01:13 AM   #8
    dlockha's Avatar
    Send dlockha:
    I'm thinking around 4000 to 4300 but that is remembering from last year took it out last weekend but 4 ft whitecaps scared me before getting wot. I just ordered smart tabs but thinking I need to change props too.
    Old 05-19-2014, 01:24 AM   #9
    You need to be in the 4400-4800 rpm range.
    Dropping to a 19P will net you another 200 rpm , 18P about 300 rpm.
    That will put you around 4500-4600 or so , if you are at 4300 rpm now.
    Right in the sweet spot.
    Might even try a 17P if you want more grunt , but the Smart Tabs will get you up in a heartbeat!
    Old 05-19-2014, 02:07 AM   #10
    dlockha's Avatar
    Send dlockha:
    Thanks for the help this is my first boat I am the second owner and the first owner only used it one week a year and kept it covered the rest of the time. I'm looking forward to getting on the water a lot this summer.
    Mercury PVS Motoxxx43 Prop Talk 2 04-16-2013 02:20 PM
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Mariah/Mercury 4.3lx Manual? joe carroll Introductions 2 08-10-2011 03:19 PM
    There are 299 users
