Mercury Spitfire
Prop Talk
Old 05-19-2014, 02:12 AM   #11
Default Re: Mercury Spitfire
Well , congrats!
And BTW...........Welcome to MOC!
  • Old 05-19-2014, 11:59 PM   #12
    Those Smart Tabs will definitely help get you onto plane faster & keep you there longer at lower rpms. If you are running a 21" prop now then dropping to a 19" 3 blade will add about 400 rpms, a 19" 4 blade about 500 rpms and to an 18" 4 blade will likely add about 650 rpms. Unless you are absolutely sure of your WOT rpms then i might consider the 19" 4 blade in an aluminum prop as your best choice. With that prop you will find a significant increase in your low to mid-range acceleration which is great for pulling toys and you will likely only lose about 4 mph off your top end.
    Old 05-20-2014, 02:00 AM   #13
    dlockha's Avatar
    dlockha is currently offline
    My Model: Barchetta 182
    My Engine: 4.3l Mercruiser
    Send dlockha:
    Thanks for all the info. I would be completely lost without everything I've read on this forum.
    1995 Barchetta 182, 4.3lx mercruiser
    Mercury PVS Motoxxx43 Prop Talk 2 04-16-2013 02:20 PM
    Throttle Control - Mercury recall bdbyrnes Original Mariah Talk 2 09-02-2011 08:39 PM
    Mariah/Mercury 4.3lx Manual? joe carroll Introductions 2 08-10-2011 03:19 PM
    There are 250 users
