Prop Pitch?
Prop Talk
Old 04-09-2008, 09:24 PM   #11
Z 202's Avatar
Z 202 is currently offline
My Model: Mariah Shabah 202
My Engine: 5.7L Alpha 1
Send Z 202:
It should be stamped on the hub.
My Mariah
  • Old 04-09-2008, 10:34 PM   #12
    It should be stamped in the hub but for a while, Mercury was using their part #'s instead so you might simply see a code. If you run into this & although i haven't checked recently, i'm pretty sure you can go to the Mercury website & enter the code in their prop selector & it will tell you the size/pitch. You could also simply go to their site & enter you boat / motor info and the selector will give you the prop that likely came with it and you can adjust from there.
    Old 04-10-2008, 02:25 AM   #13
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    You should be able to locate a number on the prop. Somewhere inside that number is the pitch. If you see a 19, 21, or 23, that is the pitch.
    Old 04-10-2008, 12:13 PM   #14
    Ok, i found my aluminum prop that was original to my boat. It has the part # 48-78122-21 showing on the hub so yep, that '21' is very likely the pitch. My other prop clearly shows the diameter & pitch on the hub as 14.25 x 21 rather than the part#. My new SS Apollo prop shows the dia & pitch also.
    Old 04-10-2008, 01:04 PM   #15
    dharby is currently offline
    My Model: 1994 Z220 Talari 350 Mag
    Send dharby:
    thx to all.....I'll take a look at it when I get the boat back from the shop
    1994 Talari z220 350 magnum
    Old 01-16-2022, 02:46 PM   #16
    Albert is currently offline
    My Model: Z215 talari
    My Engine: 5.7 bravo3
    Send Albert:
    Default Re: Prop Pitch?
    I have a 96 tamarind 215 with a 250hp io bravo 3 what pitch props should I be running. Currently mine are 26 pitch seems I have a hard time getting on plane.
    Old 01-16-2022, 05:17 PM   #17
    A "tamarind 215" ???? Did you mean a 'Talari' ? We need to know what your rpm's are at wide open throttle to be sure but you will likely need 22" or 24" pitch props with that boat.
    Proper Prop Specs? steve Prop Talk 16 04-29-2009 07:50 AM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    Z308 - Pitch and Engine question! topgunwolf Mercury MerCruiser 0 04-25-2008 10:42 PM
    prop choice Acadianbasic Prop Talk 3 08-27-2007 12:18 AM
    There are 308 users
