Planing issue
Prop Talk
Old 06-26-2013, 12:43 PM   #11
Default Re: Planing issue
Originally Posted by Andy b View Post
"Skeg"
Everytime i hear 'fin' i think of those stupid hydrofoil thingys.
And you will definitely either have to have the skeg welded or install a skeg guard. But then i'm not sure there is enough left of the skeg to install a guard.....
  • Old 06-26-2013, 12:56 PM   #12
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Mikey if you carry on like this you'll end up needing help!
    Old 06-26-2013, 01:49 PM   #13
    Like a good single malt scotch fed intravenously?
    Andy b and lumbercitybravest like this.
    Old 06-26-2013, 02:21 PM   #14
    lumbercitybravest's Avatar
    lumbercitybravest is currently offline
    My Model: 225 davanti
    My Engine: 5.0l alpha
    Gallery Images: 4
    Send lumbercitybravest:
    As much as I love replacing props, I would rather not.....Im not sure of the pitch diameter, no stamping on it anywhere. it is an aluminum prop and thats about all I know....
    Old 06-26-2013, 02:32 PM   #15
    Gallery Images: 4
    Thats why I said that Mikey....Figured its pretty early so you might as well get your blood pressure up! along with your caffiene levels...
    Old 06-26-2013, 04:31 PM   #16
    It will be stamped somewhere and that is usually on the front of the prop hub.
    Old 06-26-2013, 04:32 PM   #17
    Old 06-26-2013, 09:03 PM   #18
    Gallery Images: 4
    So I found the stamping....pretty beat up but it is a 19 inch pitch....replacing with an aluminum prop is the cheapest, but not sure if its the most cost effective....thoughts?
    Old 06-26-2013, 09:57 PM   #19
    Aluminum is the best all around choice, particularly if you have a habit of bumping into things underwater with them. SS provides only a marginal increase in performance and generally at twice or more the cost of an aluminum prop. Composite props are good for spares only and should be avoided for the most part. As for your boat/motor, the 3 blade aluminum 19" was the most common prop used. You could switch to a 20" - 4 blade along with the Smart Tabs and that should considerably help your low end 'grunt' and mid-range performance.
    Old 06-27-2013, 12:45 AM   #20
    Gallery Images: 4
    Thanks Mikey! Are the props on iboats decent? I found a 4 blade Michigan wheel vortex for $148....
    SC19 2006 planing problems theraami Prop Talk 7 12-13-2012 12:28 AM
    Starter issue usmcitalion Mercury MerCruiser 2 11-23-2011 09:08 PM
    Getting on plane issue? maybe elimont Prop Talk 4 09-07-2011 04:25 PM
    Mariah SC23 Planing problem pmcadam1 Boating 101 1 08-09-2009 04:20 AM
    There are 290 users
