Temp prop
Prop Talk
Old 06-09-2013, 08:22 PM   #11
Bulldn is currently offline
My Model: Z200 Talari
My Engine: 5.0L V8, Alpha 1
Send Bulldn:
Default Re: Temp prop
Rick,
I performed a similiar move yesterday on my "High Five" prop that I just had redone. Toasted the whole thing on a free floating submerged log in a 4000 acre lake. I since have spoken to the helpful Mikey T and done some research and found a match on Craigslist for a $45 new. Mechanically I think I'm fine but still waiting to investigate it more however. I am going to purchase a second flo torque hub as suggested. Also I plan to carry the second pro as a back up once mine is fixed again. I did take off about an inch of the lower fin unit that extends below the prop. I'm still try to determine if it is going to be and issue? In the mean time I wish you luck and will watch to see how you come out.
Derek B.
Derek B
1994 Mariah Talari Z200 Bowrider
5.7L Alpha 1
  • Old 06-10-2013, 02:08 AM   #12
    Rick Senn is currently offline
    My Model: Mariah 240Z
    Send Rick Senn:
    Kudo's to all of those who suggested the spun hub was my issue. After a few hundred dollars for a prop and a lake test, we are back in action in Vermont. I went with the 21P prop as suggested in many forums for my set up. Next up, replace the sun deck hydraulic lifts!
    Old 06-10-2013, 01:07 PM   #13
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    Originally Posted by Bulldn View Post
    Rick,
    Derek B.
    Derek, you can get a cover for the Skeg. I don't have any personal experience this them - but I know they sell them. Perhaps someone will chime in and let you know. as for needing it - I would say yes definitely, without it you will be more prone to grabbing something with your prop.
    Again - I know nothing about the replacement pieces so I cannot vouch for them. However here is the Black Fin model: Blackfin Skeg - Regarding The Outdoors
    Old 06-10-2013, 02:57 PM   #14
    If you are looking for a skeg guard that fits well and is durable I'd recommend a stainless steel one. I have a panther on my Bravo 1. The blackfin has some negative reviews I'd suggest you look into before to buying. Apparently it likes to fall off!
    I have not noticed any adverse effects of having the guard on the out drive.
    Old 06-10-2013, 02:58 PM   #15
    http://item.mobileweb.ebay.com/viewi...id=84739848531
    Old 06-11-2013, 01:28 AM   #16
    Send Bulldn:
    Thanks everyone for the helpful insight!
    I didn't even know what the "skeg" was actually called, let alone a guard was available. I'll be picking one up next week. I like the stainless-seems to make more sense. I dropped the damaged prop off today and I'm looking at $160 which isn't bad considering the damage versus investment. As I mentioned I purchased a like new 13 3/4" 21 pitch 3 blade prop on Craigslist for my 20' Talari w/ Merc 5.7' 4400-4800 RPM, 1.62 gear ratio as a back up while the other is being repaired. I'll let you know how that goes.
    Thanks again.
    Derek
    Derek B
    5.7L Alpha 1
    Old 06-11-2013, 02:01 AM   #17
    160$ to repair the aluminum prop? I am pretty sure they are like 180$ brand new... Just looking out for you! What out drive?
    Old 06-11-2013, 02:04 AM   #18
    I read through the post an saw you are an Alpha 1. Didn't mean to ask a question you all ready answered!
    Old 06-11-2013, 02:09 AM   #19
    Why not just get the skeg welded back up then repaint it to look like new? Adding a skeg guard will make it look better & you can do it yourself but if you hit something again that skeg guard will likely get ripped off along with another chunk of your skeg. Seems to me that installing one of those SS Skeg guards is like advertising that you are a rock beater.
    Old 06-11-2013, 02:38 AM   #20
    The two holes that hold on a skeg guard will definitely cause a larger fracture if you hit something!
    Aluminium fin is around 30$ the labor is $$? Zinc chromate and phantom black paint maybe 20$. The cost is not much higher to do it like new, I agree. It is hard to find someone that can weld aluminium and actually do a nice job.
    sea/air temp ual777mech General Maintenance 8 11-17-2011 02:02 AM
    Wanted: air temp/sea temp gauge mikec Mariah Parts For Sale & Wanted 0 06-01-2010 12:21 PM
    Water Temp and Air Temp Panel brettk Original Mariah Talk 4 02-20-2009 09:20 PM
    water temp clockwood Original Mariah Talk 2 01-21-2009 04:05 PM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    There are 265 users
