Prop size
Prop Talk
Old 04-28-2012, 02:53 PM   #1
Gumby is currently offline
My Year: 1990
My Model: Magnum 24'
My Engine: 350 magnum
Send Gumby:
Default Prop size
Hey guys just bought a 24' 2450 magnum 350 alpha 1 cuddy style boat would like to know what u guys think the best size prop for all arou d performance would be??? Thanx!
  • Old 04-28-2012, 04:11 PM   #2
    Default Re: Prop size
    A few questions first. What prop is on the boat now? What speed (preferably using a GPS) and what RPM's are you reaching at WOT? What do you primarily use the boat for? Cruising / waterskiiing / tubing / wakeboarding etc...
    Old 04-28-2012, 04:22 PM   #3
    My Year: 1990
    Send Gumby:
    I've only had the boat out once so he had sum kinda 3 blade 21 pitch chopper prop on it I put a what looked to b a 19 pitch prop on it an I looked like a bass. Oat throwing 1 hell of a rooster tail lol so really didn't get much of any kind of rpm/speed readings! The boat does have trim tabs not really sure how to use them tho. An I maily do cruising no skiing tubin etc! Mainly get to my party island an hang for the day! Hope that helps to help me! I just put a 23 pitch on there now but haven't made it back to the water yet
    Old 04-30-2012, 01:54 AM   #4
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    My boat is also a 24' cuddy with the 5.7 in it. When I bought it it had a 19" 3 blade on it and it was a little sluggish getting up on plane. If you had more that about 5 people in the boat, it would not even plane out unless some people got up on the bow. I dropped to a 17" five bladed "Highfive" and the boat is WORLDS better. The best thing to do is run your RPM's and speed (with a gps) then use mercury's prop finder on the website. It was on the nose for my prop and I couldn't be happier!
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 04-30-2012, 02:17 AM   #5
    My Year: 1990
    Send Gumby:
    Thanx for the info DCB so what kind of speeds does it run now an do u have trim tabs? An not rel sure on how to truly use them thanx
    Old 04-30-2012, 12:32 PM   #6
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    I'm reaching about 39 on the GPS at WOT. With the 19" prop, I was only reaching about 41 because the engine was bogging down to about 4000 RPM. I don't have trim tabs, but I plan on installing a set of smart tabs soon.
    prop size gslung Prop Talk 1 10-17-2010 07:46 PM
    Prop Size jdcooler Prop Talk 13 05-19-2010 08:54 PM
    prop size keith tindling Prop Talk 2 07-03-2009 03:33 AM
    Prop Size? karmann Prop Talk 0 06-23-2009 01:23 PM
    PROP Size? TALLRAM Prop Talk 4 07-28-2008 05:07 PM
    There are 247 users
