Proper Prop Specs?
Prop Talk
Old 12-31-2007, 03:00 AM   #11
Originally Posted by 93mariah View Post
Sorry. Ours is a 14.5 x 21, not a 17x21. My husband says you would have better performance with a 21 pitch. We've used this size prop since the boat was new.
If you are hitting 4800 rpm with a 21" pitched prop then i'd say you are just about perfect. You could gain maybe 1 - 2mph with a slight sacrifice in low end acceleration by increasing to a 23" pitch and that would drop your rpm max to about 4600 but....i dont think it's worth it. Just my 2 pennies worth.
  • Old 07-03-2008, 11:16 PM   #12
    Lars is currently offline
    My Model: 2006 SX19 4,3L MPI Alpha I
    Send Lars:
    Try this link, It's Mercurys prop selector:
    https://appcenter.mercurymarine.com/...lector/home.do
    Old 04-28-2009, 03:17 PM   #13
    Jimh23 is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha I
    Gallery Images: 4
    Send Jimh23:
    Default Re: Proper Prop Specs?
    I have a 3.0L on a 180 Diablo that came with a 14.5 x 17 prop. The WOT speed was about 38 MPH at 5000 RPM. From some research the approach for the proper pitch was one inch of pitch = 200 rpm. So I went with a 14.5 x 19 prop for some performance and proper rpm. Well the speed increased to 42 mph but the rpm remained the same at 5000 rpm. Should I consider this rpm situation a gage problem?
    Old 04-28-2009, 04:32 PM   #14
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    The max rpm for the 3.0L motor should be in the neighbourhood of 4800 rpm. Either your tach is off, or you are still underpropped and you're hitting the rev limiter.
    My Mariah
    Old 04-28-2009, 08:17 PM   #15
    You can check your tach to see if it is set at '4 cyl'. On the backside there is a small dial marked 4 - 6 - 8 etc. Just spin the dial a few times & set it at '4'. Sometimes this will correct a tach problem. If you are still hitting 5000rpm at WOT then yes, try a 21" pitch.
    Old 04-29-2009, 01:17 AM   #16
    Irace82's Avatar
    Irace82 is currently offline
    My Model: 1993 Shabah 198 4.3LX Alpha I
    Send Irace82:
    Can anyone do a "how to" post with pictures on how to change a prop? I have done some reading up on the subject but unsure of what some of them are talking about without actually putting a picture to it. And also a list of tools and lube and such needed.
    Well hopefully someone will be needing to change their prop soon haha if you do help would be appriciated. Thanks.
    Old 04-29-2009, 07:50 AM   #17
    Hi Irace82,
    Changing the prop on the Alpha is really easy and I'm sure after looking at the "How to" and doing it yourself, you'll be a pro in no time!
    (I've even done it while in the middle of a lake after our old SeaRay's prop hit a piece of drift wood or something and lost most of one blade)
    You'll find the instructions for changing the prop In the Alpha's REMOVAL, INSTALLATION AND ADJUSTMENT Manual (Section 2A), it starts at the bottom of page 2A-23.
    Here's something I found on the web with a few pictures too, click here.
    Good luck,
    Prop Pitch? borz170 Prop Talk 16 01-16-2022 05:17 PM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    z260 fuel consumption/reviews/specs koresample Original Mariah Talk 10 04-16-2008 08:12 PM
    prop choice Acadianbasic Prop Talk 3 08-27-2007 12:18 AM
    There are 302 users
