original prop
Prop Talk
Old 04-07-2009, 06:12 PM   #1
Colin Logie is currently offline
My Model: 1997 242 Talari 7.4 L Bravo 1
Send Colin Logie:
Default original prop
Need some help, Just bought a 1997 Talari 242, 7.4 L with br1. The last owner installed a custom stainless prop. I would like to go back to alumimium, just because I fear that if I strike a rock, it would damage the leg. does anyone know the specs of the original prop?
  • Old 04-08-2009, 02:31 PM   #2
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Default Re: original prop
    Colin Logie,
    I don't think you will be happy with the performance of a aluminium prop on that large of boat and engine combo! Go with a SS prop with the Flo-Torq II Hub Kit. It will give the protection you need.
    I think with that engine and the Bravo1 you will be spinning hubs on a aluminium prop.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 04-08-2009, 02:36 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    What are the specs on the current prop? Usually the switch from aluminum to stainless is a direct match numbers wise, assuming you are going with the same # of blades.
    I think the fear of drive damage due to a strike is largely overblown. Most modern props use the Flo-Torq rubber hub system, which is designed (amongst other things) to protect the drive from damage in the event of a impact.
    You will see better performance from a SS over an aluminum, especially on the 7.4L + heavy boat combination.
    Just my 0.02.
    My Mariah
    Old 04-08-2009, 06:21 PM   #4
    Send Colin Logie:
    Thanks for the info John, I was was nervous about the purchase of the Talari last week due to the lack of info and parts, one tour of this site and I wrote the Cheque ! Wonderful club. Thanks again.
    Old 04-08-2009, 07:09 PM   #5
    z275st's Avatar
    Gallery Images: 33
    Send z275st:
    I tried three props through BBlades.com.
    http://www.bblades.com/props/therightprop.cfm
    For $25 plus shipping they sent me a prop to try out. I think it was well worth the money to know which prop worked best on my boat. I ended up with a 21" rev-4 and a 23" mirage plus and a lot of knowledge from Brett (the owner). I would like to have a lab-finished 25" mirage plus. but that is BIG $$$
    John
    2001 Mariah Z275st
    496HO Bravo1
    For Sale: Original Mariah Shield decal on eBay WetWilly Mariah Parts For Sale & Wanted 95 09-07-2017 03:28 AM
    5.7 Litre and 4.3LX Alpha One, is that original? ale5jandro Original Mariah Talk 14 07-16-2008 09:01 PM
    For Sale: Another Original Mariah Shield decal on eBay WetWilly Mariah Parts For Sale & Wanted 7 05-12-2008 03:43 PM
    New owner of an original Mariah nkramer91 Introductions 3 09-28-2007 08:23 PM
    There are 311 users
