Alpha One prop question
Prop Talk
Old 07-26-2010, 11:56 AM   #21
Phlorida is currently offline
My Model: 250 Sundancer
My Engine: 5.7L Bravo II
Send Phlorida:
Default Re: Alpha One prop question
Originally Posted by Z 202 View Post
I searched your part # and came up with this: 2008 Stiletto M1419 10319 Used -Excellent - AvidBoater.com
Which is odd, because I think the pictured prop has an OMC hub...
That looks like the same one except the one I am looking at has the Merc hub. It is also brand new and $100 which is why I am interested.
  • Old 09-04-2010, 04:37 AM   #22
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    you might try the 23 pitch but have the prop punch pitched which will lower the leading edge pitch. should get out of the water the same if not better gain 2-4 mph will probably lower the rpms. however you can have your prop man check the cup and make sure it follows around the prop . this will give you your r's back as you will be able to trim the boat higher,.
    212 shabah 5.7 mercruiser alpha 1 prop help RULREY Prop Talk 5 06-23-2010 01:55 AM
    Yet another prop question Mike S Prop Talk 6 06-05-2010 01:35 AM
    prop question joel84 Prop Talk 0 05-22-2010 02:01 AM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    Just another prop question MtTalari Prop Talk 8 07-25-2008 02:41 AM
    There are 279 users
