Need a prop
Prop Talk
Old 01-07-2010, 06:07 PM   #1
Brian's Avatar
Brian is currently offline
My Model: 1994 Mariah Z200 Talari Merc 4.3L 180hp, Alpha 1
Gallery Images: 21
Send Brian:
Default Need a prop
Happy New Year to all
Daylight savings starts mar14th and spring is mar 20th.
The numbers on my prop are as follows
23380
48 832830 A 46 19 3 blade
It is on a merc alpha one outdrive on our Mariah 200z Talari. The prop worked fine and then one day we hit a shale outcrop and bent the blades and also took a chunk out of each. The plastic insert is fine. It seems to overrev as compared to how it used to be. We were looking at upgrading to a Stainless Steel 3 blade. We only use the craft for wakeboarding and tubing.
If any one has one for sale or can reccommend a website with good prices for this application would be appreciated.
I have a paypal account and can pay immediately.
Brian
610 297 1393
  • Old 01-07-2010, 06:51 PM   #2
    Tom
    Tom is currently offline
    My Model: 1994 Talari 18 4.3 LX
    Send Tom:
    Default Re: Need a prop
    I just bought a prop through iboats.com. Mine is aluminum, but I got a Michigan Wheel prop, 3 blade for just over $100 with free shipping. I went on some of the members' suggestions as to pitch. They have stainless steel as well in the 200-300 range. I'm going to buy a 4 blade as well in case the 3 doesn't have enough to get it going to ski with. I haven't decided what pitch to go with although I may just go with the one that I took off which was also a 4 blade that had seen better days.
    Old 01-08-2010, 02:45 AM   #3
    I bought a 4 blade - 20" SS Michigan 'Apollo' prop from I-boats last year. Prices were quite reasonable & as Tom notes, they had free shipping within the USA. A 3 blade 19" or a 4 blade 20" should do the trick for you and thats the two props i have. The 4 blades give a little more 'bite' and the 3 blades are slightly faster.
    Old 01-10-2010, 07:23 PM   #4
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Brian, your accident makes a good case of why I always use a prop with a break-away hub. The last owner didn't and it was a $2500 bent prop shaft and gear replacement.
    And YES spring spring sounds good! ( It was 1*F here last night.)
    John
    2001 Mariah Z275st
    496HO Bravo1
    There are 250 users
