Need prop education......
Prop Talk
Old 07-01-2009, 05:19 PM   #1
marysins is currently offline
My Model: 2000 Jubilee 204 5.0 Mercruiser
Send marysins:
Default Need prop education......
Our "new" Mariah 20' 5.0 2000 Jubilee has a 3 blade factory ( I assume ) prop. What are the advantages if any to 4 blade props? What is the difference in a 3 & 4 blade?
  • Old 07-02-2009, 12:44 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Need prop education......
    The 4 blade should offer better hole shot (quicker to plane when you hit the gas) than the 3 blade, and will likely keep the boat on plane down to a lower speed than the 3 blade. 4 and 5 blade props tend to be more useful if you do a lot of watersports; tubing, wakeboarding etc. It will come at a cost however, as your top speed will likely be slightly lower, as increasing the # of blades also increases the drag.
    My Mariah
    Mariah Education 101 David Ward Boating 101 2 11-18-2008 01:37 AM
    Mariah education blackwatch Original Mariah Talk 7 09-19-2007 10:57 AM
    There are 217 users
