Need Prop Recommendation
Prop Talk
Old 06-08-2009, 03:29 PM   #1
dleeg5199 is currently offline
My Model: 2001 180 Diablo 4.3L Volvo Penta SX
Send dleeg5199:
Default Need Prop Recommendation
The boat that I just purchased has an aluminum 14 1/2 X 19 Prop. It is the stock prop that came on the boat. The prop has been damaged and repaired. It has the Volvo Penta SX outdrive. 4.3L 190 HP Volvo. 2001 Diablo 180. I took it out this weekend and at WOT the RPM gauge was showing 5000 and could have possibly went a little higher had I not backed off. The Max RPM range shows 4200 - 4600. Did not have anything to check the speed so I am not sure how fast it was going. I am looking for a stainless steel prop to pull skiers for the most part. Top end speed is not that important, however, I don't want to keep running 400 rpms over the max. Should I stick with the 14 1/2 19 in stainless steel?
thanks
  • Old 06-08-2009, 05:51 PM   #2
    Default Re: Need Prop Recommendation
    A 4 blade 20" SS prop will lower your rpms by about 200-300 and give you a little more low / mid range bite when pulling skiiers/tubers etc. A 3 blade 21" aluminum or SS will drop your rpms by about 400 or so and get you within the recommended range. The downside is that you might lose a bit of that out of the hole / low end 'grunt' but you should gain a little cruising ability. A 4 blade 21" should reduce the rpms by about 500 and still provide the skiier towing ability. If you can get your max rpm to around 4600-4700 you should be okay. Double check the tach though and ensure that it is set at '6 cyl'. There is a small round dial on the back of the tach that you can spin around once or twice then reset at '6 cyl'. Sometimes they get a little finicky due to age / corrosion.
    Old 06-08-2009, 06:01 PM   #3
    Send dleeg5199:
    thanks, I will check the tach and make sure it is reading correctly and go from there.
    Old 06-15-2009, 12:42 PM   #4
    Send dleeg5199:
    I think I have decided to go with a 4 blade 20 pitch prop. The two that I am considering are the Michigan wheel Apollo 14 1/8 X 20 and the Solars HR Titan 14 3/4 X 20. Anyone have any options on these or any other ones they would recommend?
    thanks
    Old 06-15-2009, 01:21 PM   #5
    I have the Apollo on mine and it does a good job for the money.
    Old 06-15-2009, 03:39 PM   #6
    Send dleeg5199:
    OK, just ordered the Apollo. Hopefully it will be here by this weekend. thanks for the input.
    What prop pitch are you using for a 272 bblauvelt Prop Talk 4 07-11-2013 09:49 PM
    Need new prop...Help! monirangel Prop Talk 1 05-20-2009 01:15 AM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    another prop ? jmlanter Prop Talk 13 08-30-2008 12:18 PM
    Just another prop question MtTalari Prop Talk 8 07-25-2008 02:41 AM
    There are 221 users
