Need new prop...Help!
Prop Talk
Old 05-19-2009, 11:37 PM   #1
monirangel's Avatar
monirangel is currently offline
My Model: 1999 18' Mariah Shabah 4.3 Mercruiser
Send monirangel:
Default Need new prop...Help!
Hey Everybody,
Ready for the hot summer? We can't wait- so we ran into a little mess this past weekend, and now need to replace the prop. Bought a mercruiser 3 blade aluminum replacement but it doesn't fit the way the old one did-I guess theres a small gap all around. We have no way of reading markings on old prop as it is pretty worn and of course boat shop insisted it should fit. Any suggestions, I have info on this boat either. Its a mercruiser 4.3L and has like 180 or 190HP. We just returned the prop and now trying to find something fast. Should we stick to a 3 blade or 4 blade?
  • Old 05-20-2009, 01:15 AM   #2
    Default Re: Need new prop...Help!
    Are you sure you cant read the existing prop markings? Usually they are located on the back side of the hub which is a fairly well protected area. I'm not quite sure what you meant by "theres a small gap all around" though. Your boat likely had a 14.25" x 19" or a 14.25" x 21" prop on it. Note the diameter could be a 1/4" either way (ie 14.50 x 19). If you liked the way the damaged unit performed i would buy the same one and i would stick with a 3 blade prop.
    What prop pitch are you using for a 272 bblauvelt Prop Talk 4 07-11-2013 09:49 PM
    Prop Question Kitto Prop Talk 5 02-09-2009 07:50 PM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    another prop ? jmlanter Prop Talk 13 08-30-2008 12:18 PM
    Just another prop question MtTalari Prop Talk 8 07-25-2008 02:41 AM
    There are 343 users
