5.7 Litre and 4.3LX Alpha One, is that original?
Old 07-08-2008, 06:15 PM   #1
ale5jandro is currently offline
My Model: 1995 180 Talari 4.3LX AlphaOne
Send ale5jandro:
Default 5.7 Litre and 4.3LX Alpha One, is that original?
Hi guys,
I'm about to buy a Mariah boat.
In the outdrive says 5.7 Litre but the engine is 4.3LX.
OutDrive
http://picasaweb.google.com/AlexBeac...71928905208162
Engine
http://picasaweb.google.com/AlexBeac...71809135726930
It's that ok? should those values match?
I'm worried about somebody changing the outdrive for the incorrect one.
Alex
  • Old 07-08-2008, 06:29 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Both motors are usually mated to an Alpha drive, so my guess is either
    A) The outdrive was replaced with a salvage one from a 5.7L rig
    or
    B) The boat was repowered with a 4.3L and the existing outdrive used.
    What size/model of Mariah is it?
    My Mariah
    Old 07-08-2008, 06:32 PM   #3
    Send ale5jandro:
    Thank you very much for your answer
    It's a Talari 18ft 95/96 (I'm not sure)
    Do you think I could have issues with that ?
    Old 07-08-2008, 06:35 PM   #4
    Hmm, that's an interesting one. The engine looks factory, usually you can tell if they've been swapped. The outdrive, while it may be from a 5.7L engine, as long as it was professionally installed, shouldn't be an issue. Over the past 5 years, there's been a problem in our area with outdrive theft. Someone came by and pulled about 12-15 outdrives off in one summer. Apparently they're worth about $4-6k each. Perhaps that's what happened with yours, and it was just replaced with a 5.7L model. Maybe a used one was installed?
    Or, it could have just been the previous owner slapping a 5.7L sticker on there to look more powerful?
    I don't think the 18' Talari would be powered with a 5.7L, that seems like a ton of engine for that boat!!
    Whatever the case, I'd definitely take it for a spin before buying it. Pay attention to any vibrations, noises, or anything out of the ordinary. I'd also try and find a Mercruiser mechanic to give it a good look before signing on the deal.
    Good luck and let us know how it turns out!
    Old 07-08-2008, 06:45 PM   #5
    Send ale5jandro:
    Wow, incredible what you tell !
    I didn't know they steel outdrives. good to know.
    The boat is owned by a friend of a friend, so actually we went on the weekend to Lake Isabella.
    We were 6 on the boat and everything looked fine, we were also wake boarding 5 in the boat one in the board and was running great. But I'm not a mechanic. But I think if the installation could be the problem I think is well done. She (the owner) has the boat for about 4 years, she makes the service in the engine every year, and in the outdrive every two years.
    I just was wandering if the heavier mechanics of an outdrive 5.7L could affect an 4.3 engine.
    What do you think?
    Old 07-08-2008, 07:04 PM   #6
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Wow you guys are fast! As I go to reply there are 2 more replies since... ROFL!
    Ok so its a 95/96. Take a look around the transom on the boat for the HIN number. The last 2 digits are the year of the boat.
    1992 and up drives are going to be all Gen2.
    http://www.sterndrive.info/sterndriv..._outdrive.html
    You could just remove the decal and place a 4.3 on it hehe
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 07-08-2008, 07:17 PM   #7
    Send bpfirrman:
    My guess would be that the outdrive was changed. If my memory serves me correctly Mariah did not offer anything above the 4.3lXH in the 18 foot models. I would probably just remove the decal if that is possible.
    Old 07-08-2008, 07:18 PM   #8
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    Quick flip of the 95 / 96 brochures...
    There was no 18 ft Talari in 1996 and the 1995 18ft Talari's came with 3.0 or 4.3 and no 5.7L option.
    As Shabah mentioned, 5.7L would be overkill for it.
    ~ Ryan
    Old 07-08-2008, 07:56 PM   #9
    Send ale5jandro:
    So the conclusion would be that the 4.3 engine is original and they changed the outdrive.
    And accordingly to Shabah if the work was well done, it must not be a problem.
    I was worried about having heavier mechanics in the outdrive could affect the engine performance.
    Thank you very much guys
    Alex
    Old 07-08-2008, 09:49 PM   #10
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Overkill?!?!?!? No such thing!!!
    Alex, the lower unit is the exact same on a 5.7L as a 4.3L (if both are Alpha Ones). I agree, looks like someone had to replace the lower unit and decided on a used one from a 5.7L equipped boat. If all checks out, I wouldn't worry a bit.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    For Sale: Original Mariah Shield decal on eBay WetWilly Mariah Parts For Sale & Wanted 95 09-07-2017 03:28 AM
    Wanted: Looking for an original Mariah Monogram Sewing Machine. WetWilly Mariah Parts For Sale & Wanted 14 07-31-2012 12:00 AM
    Wanted: MARIAH original sticker / type plate mariah2350cz Mariah Parts For Sale & Wanted 1 12-01-2007 01:56 PM
    New owner of an original Mariah nkramer91 Introductions 3 09-28-2007 08:23 PM
    There are 314 users
