Good Prop for 4000 ft lake Powell
Prop Talk
Old 07-23-2013, 03:11 AM   #1
m&mmariah is currently offline
Status: Gold Contributor
My Model: 180 Shabah
My Engine: 4.3 Mercruiser 4v carb
Send m&mmariah:
Default Good Prop for 4000 ft lake Powell
Ok, I installed a 4 blade aluminum, 14 x 20 prop today for our upcoming trip to 4,000 ft. elevation lake Powell. Running a 4.3 vortec, alpha one, 1.81 to 1 ratio, 4bbl carb on a Shabah 180. Guessing this should be just about right for cruising the lake with a full tank of gas, small dog, and wife. No towing, just cruising around to check out the scenery. Might have to adjust the idle speed and the idle mixture screws, but am guessing everything should be ok at 4000 ft. Sound good?
  • Old 07-23-2013, 03:35 AM   #2
    Default Re: Good Prop for 4000 ft lake Powell
    You might have been better with a 3 blade 19" but the 4 blade - 20" will work okay for cruising around but it will suffer somewhat in performance. If you read post #3 in this thread here in the Prop forums you should find the answers you are looking for.
    Lake Powell trip from early July Motoxxx43 Trips, Travels, and Meet Ups 3 07-29-2013 12:50 AM
    Headed to Lake Powell Kitto Trips, Travels, and Meet Ups 28 07-22-2013 04:43 AM
    prop pitch for Lake Tahoe m&mmariah Prop Talk 9 04-26-2012 12:59 PM
    Will this prop fit.. and is it a good one? nglauer Prop Talk 11 09-04-2010 04:55 AM
    4.3 L misses at 4000 rpm nooner Introductions 0 05-15-2010 01:18 AM
    There are 241 users
