Another Prop thread... Which way do I go?
Prop Talk
Old 07-11-2008, 01:54 AM   #11
dieselwiezil is currently offline
My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
Send dieselwiezil:
[An update for me: Went out last weekend Top speed is 44mph and 3850-3950 RPMS. Trim indicator is half way or a little higher than half. This data is collected JUST before Cavitation begins. I guess im going to do a tuneup. It is QUITE possible all my stuff is OEM from the factory, and being 8 yrs old, it needs to be changed. It has 97 hours now. Another thing I am thinking about is that if the throttle cable may be stretched? I have seen them do it on construction equipment, so Im going to check that out too.
I cannot find my thread I had a couple weeks ago, and Im not tryin to hi-jack this one.[/QUOTE]
I just checked my throttle cable and there is NO WAY that this could be my problem. At the High Idle stop on the carb I still have almost 2in. of throw in the cable. Maybe it needs to be tuned a little richer? Im at sea level, and theres no sign of over fueling in the carb. Maybe it needs to me turned up a little bit. Any other ideas on performance.
2000 Mariah 212 Mercruiser 350
2002 F150 Supercrew
1996 F250 Diesel lots of power goodies.
"Out of everything I have, I still prefer riding MARIAH"
  • Old 07-11-2008, 02:35 AM   #12
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    dieselwiezil,
    Have you been able to try a 19p prop. It should get you in the RPM range you need to get the horse power to gain speed. With a 23" four blade I was at 4650RPM and 50mph. A change to a 21" four blade and I got 5000RPM and 53mph.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 07-11-2008, 03:16 AM   #13
    Send dieselwiezil:
    well im planning on doing a tuneup this weekend. Im going go out again to see if that made a difference. Then I will check out the prop. How do you measure the diameter of the prop? I measured from the hub shell to the tip of the blade and its roughly 5in. The hub case is 5in. Does this mean my prop diameter is 15in?
    2002 F150 Supercrew
    Old 07-11-2008, 06:44 PM   #14
    z275st's Avatar
    Gallery Images: 33
    Send z275st:
    Yes, its the center of the hub to the tip of a blade X2.
    Good luck!
    John
    2001 Mariah Z275st
    496HO Bravo1
    Prop Pitch? borz170 Prop Talk 16 01-16-2022 05:17 PM
    What prop are you running? KSP181 Prop Talk 12 11-20-2008 10:55 PM
    PROP Size? TALLRAM Prop Talk 4 07-28-2008 05:07 PM
    Prop issues 95Z212 Prop Talk 9 07-28-2008 03:55 PM
    Changing prop! Lars Prop Talk 8 07-04-2008 05:37 PM
    There are 239 users
