Xl 2000 top speed
Prop Talk
Old 08-23-2019, 09:05 PM   #1
Tscott42 is currently offline
My Year: 1990
My Model: Xl 2000
My Engine: 5.0 alpha 1
Send Tscott42:
Default Xl 2000 top speed
Newbie here... I have a 1990 5.0 alpha one that’s getting 35-37 mph at 4200 rpm and I’m told it should be going faster.
  • Old 08-23-2019, 09:15 PM   #2
    Default Re: Xl 2000 top speed
    Yep. Was there a specific question?
    Old 08-23-2019, 09:19 PM   #3
    For starters.... the engine could be 'tired' and in need of a major tune-up, prop could be the wrong one (probably needs a 19 pitch 3 or 4 blade), prop blades chewed or bent ?
    WOT with the 5.0 should be around 4800 rpms. Read thru one or more of the STICKYS at the top of the Prop Talk Forum for some additional ideas.
    Tscott42 (08-23-2019)
    Old 08-23-2019, 09:40 PM   #4
    My Year: 1990
    My Model: Xl 2000
    Send Tscott42:
    Recently installed a new 3 blade 14.25 19 pitch turning point as well as a new shift cable. Tune up will be done shortly. Just trying to get an ideal on what the mph should be around.
    Old 08-24-2019, 12:50 AM   #5
    Okay. I would suggest that boat should top out in the very high 40's but dont count on the speedo being accurate. Only turning 4200 rpm with a new 19 pitch prop indicates you have other (engine / timing) issues to be dealt with.
    Old 08-24-2019, 01:00 AM   #6
    My Year: 1990
    My Model: Xl 2000
    Send Tscott42:
    Thank you for the info. Ordering the tune up kit asap
    Old 08-24-2019, 06:58 PM   #7
    One other thing i just thought of. Have a look at the back side of the tach and ensure that it is set to "8 cyl". If not, do so and give that little wheel a few spins around before setting it. Sometimes a bit of corrosion or dirt will cause them to not read correctly.
    Top speed Stalbers Original Mariah Talk 26 01-31-2021 11:12 PM
    New to me, top speed? DcH Introductions 2 03-15-2017 11:04 PM
    No Speed Lay Lake Mark Introductions 0 08-05-2010 12:47 AM
    top speed southcoastpower Original Mariah Talk 3 06-29-2010 09:30 AM
    speed and rpm jktbea Original Mariah Talk 7 05-20-2008 03:51 AM
    There are 354 users
