best guess on prop
Prop Talk
Old 07-13-2015, 01:40 PM   #1
78 promod is currently offline
My Engine: 4.3 lx
Send 78 promod:
Default best guess on prop
I have read all the sticky notes on props, and I understand how all of it works. but, the issue I have is that I am at max rpm 4800 at like 3/4 throttle at 30mph. I have a high five 19 pitch on it now. would anyone recommend a 21 or 23 prop? I have no idea what the rpm's would be at full throttle because I don't want to open it up all the way and take a chance on blowing the motor. boat is a 92 mx19. any ideas would be appreciated
  • Old 07-13-2015, 03:36 PM   #2
    Default Re: best guess on prop
    Normally a 19" 3 blade or a 20" 4 blade would be a much better prop for that engine. If your numbers are accurate then i would suggest something else is going on. Possibly someone has regeared the outdrive, your tach is not reading correctly or that "19" High Five (which is really a ski prop) isn't pitched as a 19".
    Quick check for the tach is to access the back of the unit and spin the little wheel around 5-6 times then reset it at "6 Cyl".
    I believe the outdrive gearing ratio for your motor should be 1.81 but i'm not absolutely positive. You can check what you have by using this chart.
    Old 07-13-2015, 03:59 PM   #3
    My Engine: 4.3 lx
    Send 78 promod:
    i have only had this boat for about a month. the guy I got it from had put the prop on there. I don't really do any skiing, mainly just cruising around. I don't really like the prop because I hate the way it handles while I am in reverse. I will have to look to see what the gear ratio is when I get home.
    I guess I never learned finleydj Original Mariah Talk 15 09-09-2013 04:46 AM
    Prop Guru's... help me Identify this Prop - pics attached nglauer Prop Talk 19 06-19-2013 06:25 AM
    Getting too old to enjoy the boat I guess William Evans Original Mariah Talk 1 04-24-2009 11:17 AM
    There are 257 users
