Z280MCC Generator
Projects
Old 02-09-2010, 02:16 PM   #1
LJ's Sunset Dream is currently offline
My Engine: 502ci, Bravo III
Send LJ's Sunset Dream:
Default Z280MCC Generator
Purchased a 1999 Z280 MCC this fall (moved up from a Z252 Shabra)
This boat is so fully loaded it's not funny,Fridge, seperate ice maker, TV/VCR, hot water heater, a/c/reverse heat etc.
One option it does not have is a generator, as I've seen it listed in the options, does anyone know what the original gereratorswere, that were offered?
Any idea what size?
Manufacterer?
Has anyone added one after the fact?
Any help would be greatly appreciated.
Larry
  • Old 02-09-2010, 05:20 PM   #2
    Default Re: Z280MCC Generator
    I believe the originals were Westerbeke 5kw's. Not 100% sure on that, but I think I remember seeing that somewhere.
    Adding a genset after the fact might be a bigger project than you'd want to tackle. It's essentially adding another engine. You'll need to factor in fuel supply, cooling, exhaust, the nightmare of integrating it into your existing electrical system, etc. Not to mention I believe a new genset might run you back 3-5k.
    Old 02-09-2010, 06:01 PM   #3
    Thanks for the input.
    Using a link I found here i went to Westerbeke's website, they have a 5KW unit with low C02 emissions the 5.0 SBCG Safe-CO.
    I've requested a price, and installation info.
    After all, the ice makers awfully important on a sunset filled evening!
    Thanks again
    Larry
    Old 02-10-2010, 02:55 AM   #4
    2 OWNER MARIAH is currently offline
    My Model: 2001 222 Shabah, Phoenix Yellow w. Small Indy Style Graphics, 1999 Z280 MCC
    Send 2 OWNER MARIAH:
    what are you using now to run fridge, ice maker, tv, 110 v outlets, microwave, etc.? mine is equipped with a 12 volt/ 110 inverter. replaced it when i bought the boat 3 years ago. 2 OWNER MARIAH
    Old 02-10-2010, 02:17 PM   #5
    Well I just rec'd the answer on the generator
    Westerbeke does make a great 5KW low CO unit, in Canada it retails at $11,395.00 plus the install kit $1,159.00.
    Anyone know if it's cheaper in the US, I live in Toronto and it's not far across lake Ontario?
    Looks like I'll be continuing to use batterys and the inverter this year.
    Thanks for your help guys
    Larry
    Old 02-10-2010, 02:20 PM   #6
    Batterys and inverter
    I have two "START: batterys and a large "GEL" battery for the inverter, what size inverter do you guys have on board?
    I think the one on board is only 1000W
    Larry
    Old 02-10-2010, 11:32 PM   #7
    Larry,
    I installed a new xantrex 2500 w freedom marine inverter/ charger when i bought the boat, because the other one did not work. i added the new remote read out with it also, i was told i may have to run a new feed cable to the remote, but the original did work. (looks like a phone jack cable). i use 2 large 12 volt batteries hooked parallel to run the inverter.
    we use it mainly on weekends to run microwave, tv/dvd, coffe pot, and some small appliances and have never ran low on power. i am thinking i paid around $1300 for it a few years ago but well worth having. i prefer it over a generator because of not only the cost of maintaining, but we have friends that have them and when we anchor with them and they start them up all you hear is that noise of the engine running. ( very annoying)
    the down side of the inverter set up is that you can't run your hot water heater, fridge and stove when your away from shore power. but the hot water heater is set up to run your heated engine water through it if needed.
    Kevin
    Old 02-11-2010, 02:22 PM   #8
    Hi Kevin,
    Thanks for the input. I think that my inverter is 1000w it's the original one that came with the boat.
    I was lucky to find "Sunset Dream", she only has 220 hours, and is in immaculate shape. I have called the marina to find out the size of the gel battery that runs the invertor, it might be a great way to go(upsizing the invertor) I would really like to be able to keep the ice maker on 24/7. Thanks for the info.
    Larry
    Old 02-14-2010, 06:04 PM   #9
    Send 300sflyer:
    Larry
    Not sure what Canadian dealers are smoking... but just accross the lake you can pick one up for about 6K. Given that the US and Can $ are very close, I'd be heading south. If you decide to go, can you pick one up for me too?
    Westerbeke 5.0 BCG Gasoline Generator
    Generator on a 308Z topgunwolf Original Mariah Talk 5 02-10-2008 07:36 PM
    Honda 1000 Generator, to recharge dual batts Jeff Barnett Boating 101 5 09-21-2007 01:38 AM
    There are 230 users
