Underwater Lights
Projects
Old 02-27-2017, 06:04 PM   #1
Default Underwater Lights
Hey everyone... Just trying to bring up some conversation while we all wait for our boats to come out of hibernation!
Who's got underwater lights?
Last season I installed one of the drain plug lights from Diablo Royale Customs after researching the various manufacturers and comparing products online. Some of Diablo's marketing techniques of bashing the competition's products may seem a little sketchy and shady, but I'm here to say, they do make a quality product!
This is what I've got:
You literally just feed the wire through the drain plug, connect it to a 12v source, do a few wraps of teflon tape around the fixture, and tighten it right into your drain plug fitting! I keep my boat in the water for the entire season, so as you can imagine, I was a little concerned with leaks. Needless to say, I didn't have any!
The light I purchased online is last years model, and specs said it put out 800 lumens of light. Without having access to scientific equipment to test, I used my phone and a light meter app. It measured around 770 outside of the water using the camera on my phone (which likely isn't the best measuring device), but I'll say it's pretty darn close to 800 lumens.
The light output does have a few variables, mainly the color of light you choose, and the water it's being used in. The pics below show the light in the murky water of Sandusky Bay in Lake Erie... Light shines out for about 4 or 5 feet behind the transom. Out in open water and at the islands, the water's much more clear and the light will travel further. I wired it into my courtesy lamp circuit, and only turn those lights on when we're at the dock, or anchored, since technically US Coast Guard regulations state you're not supposed to run with any other colored lights than your nav lights while underway... I figure it's better to be safe than sorry, would hate to lose my captain's license over something like that!
Price-wise, you can't beat it. I paid $50 for it on special last year. They've now redesigned them and the light output has been increased to 1000 lumens for nearly the same price! You have your choice of aluminum or brass. You can also buy multi-fixture fittings as well which include up to 3 lights. The aluminum version is $45, and the solid brass is $55. They definitely get a positive review from me.
MTH (02-28-2017)
  • Old 02-28-2017, 02:20 PM   #2
    MTH
    MTH's Avatar
    MTH is currently offline
    My Model: Shabah 202
    My Engine: 5.7L A1
    Send MTH:
    Default Re: Underwater Lights
    Thank you for the review and the pics. I follow them on FB and they seem like they make a great product but it's hard to grasp the brightness of those lights and whether they're worth the money!
    Your pics look good, that's brighter than I would've expected for an 800 lumen! I've been looking at the 8000 lumen trying to decide if it's worth it. Was probably going to get the blue and wire in blue some led's strips (hidden) area the inside of the boat and run everything off the same switch.
    Was thinking about this bad boy lol
    https://www.boatpluglight.com/collec...-drain-fitting
    tbrookens and Firestone like this.
    99 Shabah 202 5.7 A1
    Old 02-28-2017, 02:47 PM   #3
    Keep in mind, those are pics from a cell phone camera, which isn't the best representation at night due to all the auto enhancing features, but it does put out a pretty impressive amount of light for $50. I can only imagine their larger lights are even more awesome.
    With the blue light, I definitely recommend a higher powered setup, especially if you'll be using in any sort of darker water. My dock neighbor has a blue knockoff drain plug light (one of Diablo's competitors) that was supposed to put out 800 lumens, and it's incredibly hard to see, he's quite jealous of mine
    Firestone and MTH like this.
    Old 03-06-2017, 01:43 AM   #4
    I was given a plug light two years ago as a gift. I put it in for one outing and ended up leaving it out. I have no idea how it worked as I never hooked it up though. I chose to leave it out because our lake has these ridiculous inspections we have to do every time your boat either goes on or off the water. I still want to hook it up and put connectors on it so I can unplug it easily and dont have to tow with a plug dragging.
    For those interested in night fishing I understand every body of water may have laws about illuminating the water. Thankfully that does not apply to our lake. From what I can gather green is the color to have when trying to attract fish.
    Thanks for the motivation to get that plug in!
    Old 03-08-2017, 05:04 PM   #5
    MTH
    MTH's Avatar
    My Engine: 5.7L A1
    Send MTH:
    Hey just out of curiosity, did you wire yours to a switch ShabahZ280? And did you have any additional lights wired in with it?
    Old 03-08-2017, 07:41 PM   #6
    I agree with Motoxxx43, the green, or the white lights attract the fish
    Yes, I have my drain plug light wired into my cockpit courtesy lamps circuit. I can switch it on and off from the helm. I picked this one for two reasons.
    a) I only keep my courtesy lamps on at the dock or while anchored/moored.
    b) the courtesy lamp just happened to be one of the closest factory-wired switched circuit to the drain plug!
    There are 3 or 4 of the oval courtesy lamp fixtures wired into that circuit as well. I swapped all the courtesy lamp bulbs to LED's so it's not a heavy circuit draw.
    MTH (03-08-2017)
    Old 03-10-2017, 02:10 AM   #7
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I just discovered that my boat has the light too. I might never have guessed without having seen this topic. Was this an option from the factory?
    Thank you GaryDoug for this useful post!
    ROY850 (03-25-2017)
    Old 03-10-2017, 05:36 PM   #8
    MTH
    MTH's Avatar
    My Engine: 5.7L A1
    Send MTH:
    Nice! I don't think that's factory. Any pics of the light housing itself? Looks pretty bright.
    Old 03-10-2017, 06:44 PM   #9
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Here is a photo. There is a glass lens on the back end. I think I found the reference to the light option in the 98 Brochure:
    1996 Mariah Z252 (05-30-2017)
    Old 03-10-2017, 07:52 PM   #10
    I think what the brochure is referring to is a light that light up the topside of the swim platform. That part looks like the typical drain plug light so many folks are making these days. ( LEDs epoxied into a NPT fitting from the local hardware store)
    Sent from my XT1585 using Tapatalk
    Thank you Motoxxx43 for this useful post!
    Underwater LED lights in drain plug Shabah203 Original Mariah Talk 11 05-28-2015 01:57 PM
    Custom Underwater LED Lights John Rush Projects 8 05-17-2014 01:01 AM
    Underwater lights voodoo Original Mariah Talk 13 03-26-2012 03:52 PM
    bow lights? spot lights? need some help... with night time navigation nglauer Original Mariah Talk 13 07-09-2011 06:36 PM
    Wanted: Underwater Lights topgunwolf Mariah Parts For Sale & Wanted 3 06-10-2009 01:26 AM
    There are 351 users
