subwoofer box for marine??
Projects
Old 04-23-2008, 01:57 PM   #11
180diablo's Avatar
My Model: 1993 Diablo 180
Gallery Images: 30
Send 180diablo:
I'm not even going to comment on my radio setup. Ummm, you can hear it when the boat is off.
Otherwise this is my new "system" for the summer:
(not exactly.. but close)
Moondance: I know you have posted pics up somewhere of your system..... Please post them up again !!
~ Ryan
Owner of the 3.0L Powerhouse!
  • Old 04-23-2008, 06:18 PM   #12
    Send bpfirrman:
    How is the sound with the bandpass box being being completely covered in the back? That would obvioulsly be the easiest set up and would not require any more drilling of holes underneath the rear bench. Just a little concerned the sound would be muffled quite a bit.
    Old 04-23-2008, 06:30 PM   #13
    the sound is a little muffled, but honestly I don't notice it very much. with bass being non-directional, you can shoot it pretty much any way and still get full effect of it. Inside the boat it sounds great. I really only use it when anchored, tied up, or slow cruising.
    Old 04-23-2008, 08:29 PM   #14
    Oh man, 180diablo....ya gots to get with the times yo, it's got to have more power and an Ipod hookup so we thinks this ones da perfect one fo yous so here ya go!
    Hope it don't sink your boat...
    P.S. I used a portable for almost 5 seasons on our second boat!
    Old 04-24-2008, 08:35 PM   #15
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    HAH .... actually I could probably use that to hold down my boat. Might even hold it down in rough choppy water!
    The portable radio I showed above, I won it as part of a draw. So I figure I wouldn't use it around the house and would probably use it more on the boat. Then I wouldn't need to rely on the boat and can move it around if we are in the water etc.
    ~ Ryan
    Old 04-25-2008, 12:08 AM   #16
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    Ryan, I'll get some pics up this weekend when I get home. I don't have any on my laptop. I was excited this srping when I got it out, charged the batteries and everything worked!!
    Doug
    95 Z240 Talari, 502, Bravo 3
    Old 05-01-2008, 05:38 PM   #17
    MariahMX20 is currently offline
    My Model: 1991 MX20
    Send MariahMX20:
    Smile
    well i have figured out that i am going to be mounting a 12" alpine type r subwoofer under the dash on the drivers side, there was a ton of empty unused space up there that i found once i removed the panel going down to the floor. i was able to build a ported box that fits up there really well. this is great becasue i keep my boat in a marina and if someone gets into my boat i doubt that they are going to find the subwoofer up there. i am also mounting my 5 channel amp onthe backside of that panel which you have to remove to even access the amp so its all hidden! i will let you guys know how it works out once its all done.
    Old 05-03-2008, 02:10 PM   #18
    Send moondance100:
    By all means, keep us posted! Have you given any thought to how you're going to power that monster? Battery wise I mean...
    Doug
    Old 06-15-2008, 07:41 PM   #19
    Gunner is currently offline
    My Model: 1998 Jubilee 214
    Send Gunner:
    Default Bazooka the way to go
    Dropped a pair of 10" Bazooka self-amplified in my Jubilee. put one forwardin in the storage locker to the right. Put the second under the sink(mid boat) on the left. It sounds incredible. Try the theme from Pirates of the Carribean. Has a lot of range and boy it sounds great.
    Considering putting an 800 watt amp in the boat for the primary speakers. Was thinking of mounting in the empty spaces between the console and the built in john. Was worried about heat buildup though. Any thoughts?
    Old 06-16-2008, 12:15 PM   #20
    I would be a little concerned with heat buildup, in a closed spot, however if there are any vents, that would help. An 800W amp probably doesn't put out a ton of heat, but you never know, and if it's got a thermal protection circuit built in, this will get real annoying when it keeps turning itself off. My 600W amp is attached to the port side of the engine cover, it has enough ventilation there. It's always getting air in and pushing air out due to the vents on the back.
    Dmaxx85 (05-16-2013)
    southwater marine edward cossey Chit Chat/Off-Topic 1 03-31-2008 01:59 AM
    Marine ACDC electrical site mikeyt General Maintenance 0 03-05-2008 12:37 AM
    Trailer tips from Club Marine magazine dudders Trailering and Tow Vehicles 4 02-28-2008 03:03 PM
    Marine wax and polishing brands MariahMan General Maintenance 14 07-24-2007 01:48 AM
    There are 235 users
