Aftermarket Headers 7.4 MPI
Old 02-21-2015, 06:57 PM   #1
watertoad is currently offline
My Model: Z250 LE
Send watertoad:
Default Aftermarket Headers 7.4 MPI
Looking to maybe do some aftermarket headers for my 00 Z250 LE with the 454 MPI engine. Any idea on good brands or where to buy?
2000 Mariah Z250 LE
Phoenix Yellow with Black Checkered Flags
Mercruiser 7.4L MPI 454 / Bravo 3
Kiekhafer Shifter
  • Old 02-22-2015, 11:22 PM   #2
    Default Re: Aftermarket Headers 7.4 MPI
    This is an interesting topic here. I have a 250 with 7.4 MPI as well. I tried doing the same in hopes of maybe some performance gain- or? Did a lot of research and even bought a pair of EMI Thunders from a fellow member on MOC. Long story short they are not on my 7.4.
    Ill sum up some experiences for you. The 7.4 is not really like the 454/502 motors. The terms kinda confuse folks due to displacement being 454ci in both the 7.4MPI and 454. That is about all they share. The 7.4MPI have what they call peanut port heads where the 454 has larger rectangle port heads. That is the first problem- headers you may find for a "454" will NOT fit the 7.4.
    Now IF you were to strap a pair of aftermarket headers on the 7.4 you may run into another problem. Apparently the 7.4 is programed lean from factory for emissions. You throw on some more efficient flowing headers and you may lean out the motor past a safe limit. Do I know this for a fact? Never done it myself but I have read into it a lot. Feel free to hop on offshoreonly.com or powerboatnation.com or iboats.com. There is a ton of info. Some good some bad and some very questionable.
    If you were looking to just replace the stock set up due to rust or whatever I would prob go with Mercruisers OR GLM. GLM is suppose to get you a little performance and they also offer an aluminum set that shaves of a decent amount of weight. I read in a performance boat article they actually did do a pretty good improvement on a boat running near sea level. GLM info HERE.
    Another thing to consider, Mariahs were built to be sporty, luxurious and cruise well. That is different than the go fast boats built for speed and performance. Just something to keep in mind.
    Old 03-03-2015, 08:30 PM   #3
    donly1's Avatar
    donly1 is currently offline
    My Model: 268 MCC
    My Engine: 5.7 350 MAG EFI Bravo3
    Gallery Images: 13
    Send donly1:
    I would also like to see some input about the GLM exhaust kit for my V8....
    2001 Mariah 268MCC 5.7EFI Bravo3
    Thank you donly1 for this useful post!
    Dezracer (03-17-2015)
    Old 03-14-2015, 12:40 PM   #4
    jayws6 is currently offline
    My Model: Z255 Shabah
    Send jayws6:
    I haven't tried these personally but hearing lots of good things about them. You may want to check these out http://www.hitekmarine.com.au/ Just noticed there is a customer with a testimonial on their site with a Mariah Z255.
    Aftermarket Bimini Top dharby Original Mariah Talk 17 03-24-2011 09:49 PM
    Aftermarket Depth Gauge Kitto Original Mariah Talk 16 07-13-2010 02:02 PM
    5.0 305 V8 Headers?? 95Z212 Mercury MerCruiser 1 09-15-2009 03:13 AM
    Aftermarket Depth Finder Suggestions? stereoman405 Original Mariah Talk 0 06-25-2009 05:33 AM
    Are these Mariah exhaust tips or aftermarket? John Miller Original Mariah Talk 5 04-21-2009 11:19 PM
    There are 250 users
