Aftermarket Bimini Top
Old 01-24-2008, 11:29 PM   #1
dharby is currently offline
My Model: 1994 Z220 Talari 350 Mag
Send dharby:
Default Aftermarket Bimini Top
Have a 1994 z220 Talari.....don't like the factory bimini - snaps on the windshield.
Has anyone installed an aftermarket bimini? Wondering what size to get (6 or 8 ft available....seems 7 would be about right..??). I'm thinking 25-35" rise if I can mount to the existing mounts....barely tall enough to stand under providing max shade.
1994 Talari z220 350 magnum
  • Old 01-25-2008, 03:55 AM   #2
    Hi dharby,
    The top you have is typically referred to as a convertible top where as the Bimini is relatively flat front to rear and from what I have been told, is designed for running at slower speeds.
    Any good canvas shop can make a Bimini top and support bows to your specifications while using your existing mounts. With a top that long, you will need a second set of bows and mounts in the rear.
    I suggest you use only Stainless Steel poles and components; they last almost forever as compared to plastic or aluminum. Another thing, if you do go long with the top, you might what to invest in the larger diameter 1" tubing verses the 7/8"as well. You also have quite a choice in materials but from my experience, I'd choose Sunbrella.
    We have a 1996 Z240 Talari and I am working with a local Canvas shop that did my bow and windshield covers. I'm looking at going about 8' long and just and about 74” from the floor to the underside of the top so I can stand under it and still have shade all the way back to the sun pad. Now because I plan to go with a long top, I too will need will need to have another set of mounts installed towards the rear for the second set of bows as well.
    Regardless of whom you have do the job, first ask to see their work on other customer boats to make sure quality, fit and finish is up to your standards and inquire about the warranty they offer on their work as well.
    Good luck,
    Old 01-25-2008, 11:15 AM   #3
    Send dharby:
    Thks for the advice WetWilly. For front & rear mounts I was thinking steel poles on the rear (allowing me to stowaway/foldup the top in the upright position) and ties for the front. Was considering doing this myself as it seems I only have 4 mounts to attach - and then some assembly. Is it going to be tougher than I think? I'm a so-so DIYer...did install stereo and some other small stuff, yet have a pro winterize me and do anything engine/drive related.
    Old 01-25-2008, 01:28 PM   #4
    Geno is currently offline
    Send Geno:
    Default Biminy Tops
    Hi, What WetWilly said is accurate. Bimini tops do not fasten to the windsheild but sit above it. Wind gets under the top. (So does rain) You can buy a bimini top from places like Overton's and, depending on your budget, they are probably cheaper than having a trim shop make one custom. They are not what I would call difficult to install but may be a little flimsey for speeds above about 35 MPH. My 18' Mariah Diablo factory convertible top covers the driver and passenger seats well and lets everybody else bake in the sun. I have installed biminis on two different boats.
    Old 01-25-2008, 05:23 PM   #5
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Geno: What year Diablo do you have ?
    On the topic of tops, I would be interested in getting a support pole for my top so that the top can stay up and above us, rather then stored along the side of the boat OR left back at the dock
    The photo below basically is the idea I had for mine:
    OK .. .gotta get back to work now ... ROFL!
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 01-25-2008, 06:44 PM   #6
    Send Geno:
    Default My Mariah
    I have a 1993 Diablo 180 in the outboard model. I have found that outboards have some very definite advantages in terms of lighter weight, easier service and greater fuel economy with the right one. I have a Suzuki 140 4 stroke efi on this boat.
    Old 01-25-2008, 08:25 PM   #7
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    Oh yeah, I think I remember seeing the boat somewhere on here, unless of course there is another 93 Diablo O/B on here
    ~ Ryan
    Old 02-06-2008, 11:18 AM   #8
    Send dharby:
    Ryan - your picture is exactly what I want to do. I think I need a 36" tall by 79-85" wide top. The length is my dilemma...8ft seems too long, 6ft too short (only covering front 2 seats). Can't find a 7ft top. Have seen the metal polls to hold the top up for storage (as in your picture).
    Almost ready to pull the trigger and try this myself. May take the cheap route (aluminum and white vinyl) in case I don't like it. I think my Mariah top is aluminium and white vinyl anyway.
    Old 04-14-2008, 11:26 AM   #9
    Send dharby:
    Default Installed aftermarket bimini this weekend.
    I bought and installed the $250, 8ft x 74-78" x 36" 4-bow Marine white vinyl cover from Overton's. It was simple - only took an hour - and looks to be just right. Now I wish I had sprung for stainless hardware . I have pics if anyone interested (email me at [email protected]).
    I put it on a 1994 Talari z220.
    Old 04-15-2008, 11:29 PM   #10
    Send dharby:
    Did the 8ft top and it turned out well (I think it did.
    Pictures of the top (and new bow teak floor) uploaded to 1994 dharby's talari z220.
    Trailering with Bimini Top being up. Douglas Alderman Original Mariah Talk 7 04-29-2008 12:26 AM
    For Sale: Sea Fox Mariah Bimini Top for Sale on Ebay WetWilly Mariah Parts For Sale & Wanted 2 02-07-2008 08:18 PM
    There are 433 users
