need advice, quickly
Old 10-23-2014, 01:53 AM   #11
JaydubyaZ210 is currently offline
My Model: Z210 Shabah
My Engine: 5.7
Send JaydubyaZ210:
Default Re: need advice, quickly
Okay so it may not be the coupler. It is very likely the upper unit only. Took the top cover off and it is all mangled up. So I have been checking ebay and craigs list for used outdrive. What i am finding is that it is easier and cheaper to replace the whole outdrive. New or reman outdrives are over $1000, not in my budget. Anyone have any ideas other than searching for used ones? Any way to tell what kind of shape a used one is in before i buy it?
Help appreciated.
#Kindadepressed
#whitewinetasteonbudweiserbudget
  • Old 10-29-2014, 05:41 PM   #12
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    You might not like this, but you are probably better off getting your outdrive reconditioned than putting money into an unknown second hand unit.
    That is unless it's coming from a respected breaker and has some sort of warranty.
    You've already got one poorly unit, no point in buying another if you can help it!
    How bad is yours?
    Old 10-29-2014, 05:51 PM   #13
    My Engine: 5.7
    Send JaydubyaZ210:
    Well I found a complete unit for $300. Ran it on the sellers boat before we removed it to take home. Drive lube was clean. We got it put on with no problems and it runs good. I figured if it lasts a season it's worth what I paid.
    I've got a LOT of interior work to do and I have some electrical issues to sort out, just lighting, oh and the tilt and trim gauge isn't reading. The exterior is cleaning up really nicely. Should have a boat worth being seen in by end of March.
    Advice Clive Introductions 1 09-29-2010 10:25 PM
    need advice bdydrpranger95 Original Mariah Talk 7 08-04-2010 10:55 PM
    Need Advice Mariah Z202 Boating 101 3 07-16-2009 01:12 AM
    Advice brucedennis1 Original Mariah Talk 2 04-02-2009 10:33 PM
    Need Advice Please Sheli Sea Fox - Mariah Talk 6 07-23-2007 01:43 AM
    There are 211 users
