Engine starting problems
Old 10-14-2012, 11:44 AM   #1
wackyd1 is currently offline
My Year: 2006
My Model: sx18
Send wackyd1:
Default Engine starting problems
Hi all, after a couple of weeks of not using the boat I will go to start it up and will have issues.
First I have 1 gel battery and the volt meter will read around 5 volts. (low I know) Then I will turn the key and I will hear it just click. after maybe 5-10 times of trying and clicking it will turn over and start. After have run for 10min its fine on the water for the day and volts will go to around 12 volts. This happens every time when left for a couple of weeks or more . Anything I can check.......Have sx18
  • Old 10-14-2012, 01:25 PM   #2
    allz28's Avatar
    allz28 is currently offline
    My Model: z210 Shabah
    My Engine: 5.7L Merc
    Send allz28:
    Default Re: Engine starting problems
    I'm no mechanic, but it sounds like your battery isn't holding a charge anymore. I'd take it to a local autoparts store and have it tested.
    Old 10-14-2012, 02:58 PM   #3
    You need to check and see that you don't have a draw from a accessory somewhere. One thing I learned is if the internal regulator looses a diode in the alternator it can cause a short , which in turn can cause a draw.
    Also check your cables , from your description , sounds like loose cable/wire possibly also.
    As allz stated you need the battery tested also. If it is getting that low all the time it has probably destroyed it.
    Larry
    Engine problems truckingeorgia79 Original Mariah Talk 29 05-12-2012 11:07 PM
    starting problems sergio1209 Original Mariah Talk 4 04-13-2012 05:59 PM
    Ongoing problems starting 454 chriscorbett Mercury MerCruiser 15 08-29-2010 03:19 AM
    Intermittent Starting Problems Weezer Original Mariah Talk 4 11-20-2009 12:12 AM
    New member: problems cold starting boat steveog17 Original Mariah Talk 2 09-04-2009 02:04 AM
    Total Threads: 13,324
    There are 313 users
