Fuel Pump
Old 07-07-2014, 05:07 PM   #1
swoodworth is currently offline
My Model: Z202 shabah
My Engine: 5.7L
Send swoodworth:
Arrow Fuel Pump
Hey guys, I have been trying to figure out a solution to my vapor lock issue and have narrowed it down to 2 possible solutions. I have read that changing to an electric fuel pump would solve the problem, however I didn't know if an inline fuel cooler would also help to solve the problem? It seems as though this would be the cheaper route!
Has anyone made the change to the electric fuel pump? If so what were your results and how hard was it to switch over?
Any advice would be much appreciated!!
I should add that I have a 95 Z202 Alpha One.
  • Old 07-07-2014, 09:02 PM   #2
    Default Re: Fuel Pump
    I'd just put a electric on , insulate the line to carb , and be done with it.
    I'll bet that route is cheaper than a inline cooler setup too. Plus you never know if the cooler is going to fix the vapor lock. You know the electric pump will fix it.
    JMO
    Old 07-08-2014, 02:50 AM   #3
    My Engine: 5.7L
    Send swoodworth:
    Yeah that is what I was leaning towards. Just nervous since I haven't done it before...guess I will just have to do my research on here before working on it!
    Old 07-08-2014, 03:22 AM   #4
    I got faith.
    It's pretty straight forward.
    Old 07-26-2014, 07:07 PM   #5
    badjudgement is currently offline
    My Model: Z2350
    My Engine: 454
    Send badjudgement:
    To go electric (correct install) you will need an oil pressure switch to power on a dedicated fuel pump relay, I highly recommend using a marine pump as the U.S.C.G will check it if you are ever boarded. You will need to fabricate all fuel lines. This wont stop vaporlock though which is caused by fuel boiling in the carb and creating high pressure. You need a phenolic carb spacer or find out why the carb is getting so hot in the first place. Are you running a 160 thermostat?
    Old 07-26-2014, 07:11 PM   #6
    My Model: Z2350
    My Engine: 454
    Send badjudgement:
    A little clarification on the oil pressure switch, it creates an open circuit with no oil pressure (engine off) to prevent the pump from running. When you crank the engine and a predetermined oil pressure is achieved the switch closes and the pump turns on.
    Old 08-04-2014, 01:59 PM   #7
    Cory's Avatar
    Cory is currently offline
    My Engine: 5.7
    Send Cory:
    I hope this will help someone having the same issue as i have been having. My boat would run perfectly for as many hours as you needed, but once I would stop for a bit it would not want to restart. It would start up and die. After sitting for a while it would start up and run perfectly. Did alot of reading on this and the solution I tried worked. Mercruiser check valve 1 1/4'' for $85. It goes inline on your water intake hose between fuel cooler and thermostat housing. It keeps the hot water from running back down to fuel cooler and boiling fuel. Now that I have spent $85 plus shipping Im hoping to save someone some money. Look on amazon for Campbell Mfg SLC-125 Acetal Polymer Spring Loaded Check Valve $13.09 with free shipping. All you will need is fittings for water hose and put in you own drain plug. I do have a picture if someone can tell me how to post it. Hope this will help someone. Put valve in yesterday and did not run blower fan just to try and make it hot in the engine compartment and not 1 issue. Ran boat all day..
    ColoradoDiablo and swoodworth like this.
    Thank you Cory for this useful post!
    mikeyt (08-07-2014)
    Old 08-04-2014, 02:18 PM   #8
    Cory ,
    Click on "edit post"
    Click on "go advanced"
    Scroll down page til you see "manage attachments" and click on it
    Select pic from your puter
    Upload , and done
    Old 08-07-2014, 02:24 PM   #9
    My Engine: 5.7L
    Send swoodworth:
    badjudgement -- my thermostat can read up to 250 i believe but never goes past 175...
    Cory -- Looking forward to seeing that picture! sounds like that might be an easier fix!!!
    electric , fuel , inline fuel cooler
    4.3 LX Fuel Pump KelRem Original Mariah Talk 25 08-23-2011 01:00 AM
    Is this the fuel pump ? shoup2010 Mercury MerCruiser 6 07-11-2010 02:24 PM
    fuel pump help pls fl_bill Original Mariah Talk 9 07-03-2010 02:25 AM
    Fuel pump issues. jetscat7 Original Mariah Talk 4 05-09-2010 06:40 PM
    looking for fuel pump urim Original Mariah Talk 0 01-18-2010 12:25 AM
    There are 299 users
